Early on the learning curve: for loops
I'm trying to familiarize myself with the way Igor works, but I'm lacking certain key information on how to do things. In particular, how to use do loops inline(possible?) or in a Procedure. The following trivial example:
Make/N=4/D xx,yy
xx=1
yy=0
for (ii=1; ii<4; ii+=1)
xx=xx+1
yy=xx*xx
print xx,yy
gives me an error ('expected wave name, variable name or operation' at the "for" line) when I type in the commands sequentially like Python will let you do. So I presume sequential commands like this aren't allowed.
If I enter the same sequence into a new Procedure window, it compiles OK (ie no error message), and I can save it. But now I need to understand how to invoke/run it.
Igor is sufficiently different than anything I've used before that I can't work out the analogies with what I know. The "Guided Tour" section uses a much more detailed example, which I can emulate but which I can't see how to apply in this simple case.
Help appreciated.
November 30, 2010 at 02:06 am - Permalink
I can get do-while working as a Macro:
Macro test()
Make/N=4/D/O xx,yy
xx=1
yy=0
Variable ii=1
do
xx=xx+1
yy=xx*xx
ii+=1
while(ii<4)
print xx,yy
EndMacro
which I can immediately run from the macros menu item. However, for-loops won't run in macros, I find. So I was wondering how to create a procedure rather than a macro (the manuals say procedures are preferred over macros), and then how to run it in the absence of a menu option.
DN
November 30, 2010 at 04:28 am - Permalink
you can execute this code by typing
into the command line. Check out the chapter IV-3; Programming; User-defined functions of the manual.
November 30, 2010 at 04:57 am - Permalink
November 30, 2010 at 05:03 am - Permalink
November 30, 2010 at 11:14 am - Permalink
November 30, 2010 at 06:34 pm - Permalink
