StatsChiTest P calculation
In the results of StatsChiTest in W_StatsChi table,
StatsChiTest/T=1/S exg,ggg
n 200
df 199
Chi_Squared 0
Critical 232.912
P 1
How does Igor Pro calculate the value for P?
KurtB
Supriya Balaji wrote: In the results of StatsChiTest in W_StatsChi table,
Here is some code that appears to reproduce the values calculated by
StatsChiTest/S
Function ChiSqTest()
	// make some fake data
	Make/O/I/U/N=(200) wObserved, wExpected
	wExpected[] = 100 + 10 * sin(x/10)
	wObserved[] = wExpected[p] + gnoise( sqrt(wExpected[p]) )
	// plot data
	Display  wExpected, wObserved
	ModifyGraph mode(wObserved)=3,marker(wObserved)=1,msize(wObserved)=0.5
	ModifyGraph rgb(wObserved)=(0,12800,52224)
	// Run test
	StatsChiTest/T=1/S wObserved, wExpected
	// manually compute values
	Variable vNum = DimSize(wObserved, 0)
	Print "Num:", vNum
	Variable vDoF = DimSize(wObserved, 0) - 1  // Degrees of Freedom
	Print "DoF:", vDoF
		// Chi_Squared:
	Make/O/D/N=(DimSize(wObserved, 0)) wChiSqSum
	wChiSqSum[] = ( (wObserved[p] - wExpected[p])^2 ) / wExpected[p]
	Variable vChiSq = sum(wChiSqSum)
	print "ChiSq:", vChiSq
		// Critical Value
	print "Critcial Value:", StatsInvChiCDF(0.95, 199)
		// p-value
	print "p:", 1 - StatsChiCDF(vChiSq, vDoF)
Hope this helps,
Kurt
