Filter for CreateBrowser
It would be nice if CreateBrowser offered the option not only to display waves in general, but also to specify more detailed requirements for the waves (or variables etc.), such as the number of dimensions. (In the Data Browser, some properties can be displayed as Visible Columns, which could be used as filter criteria.)
You are right, CreateBrowser does not currently support filtering by wave properties such as dimension count, data type, or size. It can show or hide object classes (waves, variables, strings) and do name-based selection, but not property-based filtering.
Current options:
Most powerful filtering (dimensions, numeric type, size, custom checks).
Can be tailored to the exact workflow.
Reusable once built.
More implementation complexity.
Higher maintenance burden than a built-in command.
Can be overkill for simple one-off tasks.
No new UI code required.
Fast to adopt for teams already using structured naming.
Works with existing CreateBrowser/ModifyBrowser workflow.
Depends on naming discipline rather than true metadata filtering.
Can miss edge cases or include false matches.
Simpler than a full WaveSelectorWidget / PopupWaveSelector integration.
Very focused user experience.
Usually less general and less reusable.
You still need custom code to gather and validate candidates.
If you need help implementing whatever you choose, let us know and we'll work together on it.
Kris
July 6, 2026 at 01:29 pm - Permalink
