Progress Window
Creates a progress window panel(s) which supports hierarchical progress bars that are easy to activate/update/deactivate from a function. Overhead for updating the progress window is minimal.
| Project CVS: | http://svn.igorexchange.com/viewvc/packages/progresswindow |
progresswindow IGOR.6.20.x-2.x-dev
| Release File: | progresswindow-IGOR.6.20.x-2.x-dev.zip (1.61 KB) |
| Version: | IGOR.6.20.x-2.x-dev |
| Version Date: | |
| Version Major: | 2 |
| Version Extra: | dev |
| OS Compatibility: | Mac-IntelWindows |
| Release Notes: |
Usage has been simplified. At the beginning of the body of a loop (for/while), add a Prog() command. The window will clean itself up when done. For example: The messages "Outer" and "Inner" can be whatever you want. The other two arguments are the numerator and the denominator of the fractional progress for that part of the loop. The button created in the progress panel will, if pressed, abort the next type the Prog() command is encountered, enabling you to abort after a complete pass through a loop, rather than in the middle of a loop. |
