Main navigation
Products
Igor Pro
Igor Pro 9 Highlights
New Features
Igor Pro 9 Changed and New Features
How to update
Previous versions
Igor Pro 8 Highlights
Igor Pro 8 Changed and New Features
Igor Pro 7 Changed and New Features
Igor 6.3 reasons to upgrade
Igor 6.3 new features
Igor 6.3 changes since release
Igor 6.2 new features
Igor 6.2 changes since release
Igor 6.1 new features
Igor 6.1 changes since release
Igor 6 New Features
Igor 6 Release Notes
Unique Hybrid Interface
Data Access
File Formats
Binary Files
HDF5
Hardware Data Acquisition
Export Formats
Internet Support
SQL Databases
External Access
Data Storage
Data Folders
Creating Graphics
2D graphs
XY plots
New graph details
Trace settings
Axis settings
Category Plots
Contour Plots
Flexible axes
Animations
Preferences and templates
Page Layouts
Tables
Drawing tools
Annotations
Color Tables
Subwindows
3D and Volume
Surface Plots
Path and Ribbon Plots
3D Scatter
3D Object Plots
Isosurfaces
Voxelgrams
Volume Slices
3D Animations
Exporting Graphics
Image Processing
Image Acquisition
ROI
Image Transforms
Mathematical Operations
Histogram Modifications
Image Interpolation
Image Registration
Background Removal
Image Rotation
Color Spaces
Thresholding
Localized Filters
Edge Detectors
Morphology
Image Analysis
Image Statistics
Line Profile
Particle Analysis
Image Snake
Data Analysis
Curve Fitting
Built-in types
User-defined
Constraints
Errors in Variables
Global Fitting
Multidimensional
Peak Analysis
Peak finding
Baseline removal
Multi-peak fitting
Signal Processing
Fourier transforms
Spectral windowing
Power spectra
Hilbert transforms
Time frequency analysis
Digital filters
Smoothing
Convolution and Correlation
Level detection
Statistics
Statistical Tests
Angular Distribution Tests
ANOVA1 Tests
ANOVA2(NR) Tests
ANOVA2(RM) Tests
Chi-Squared Tests
Angular-Correlation Tests
Circular Means Tests
Circular Moment Tests
Circular Two Sample Tests
Cochran Test
Dunnett Test
Friedman Test
F Test
Hodges-Ajne Test
Jarque-Bera Simulation
Kendall's Tau
Kolmogorov-Smirnov Test
Kruskal-Wallis Test
Linear Correlation
Linear Regression
Multi-Correlations
NP Multi-Comparison
Nominal Serial Randomness
Spearman Rank Correlation
Bootstrap and Jacknife
Scheffe's Test
Serial Randomeness
T-Test Examples
Tukey Text Examples
Variances Test Examples
Watson's U2 Test
Watson-Williams Test
Wheeler-Watson Test
Wilcoxon Tests
Weighted Rank Correlation
Noise Functions
Probability Distribution Functions
Cumulative Distribution Functions
Inverse CDFs
General Purpose
Procedures and Packages
Computational Geometry
Data Manipulation and Math
Mathematical Functions
Matrix and Linear Algebra
Analysis of Functions
Plotting
Optimization
Root finding
Integration
Ordinary differential equations (ODEs)
Igor Filter Design Laboratory
Filter Designs
Data Exploration
Programming
External or Internal procedures
Color coded editor
Contextual help
Packages
Debugger
Custom Interfaces
Controls and control panels
Control types
Custom menus
Notebooks
On-line Help
Manual
Video Tutorials
NIDAQ Tools MX
Details
Applications
Supported Hardware
Requirements
XOP Toolkit
Versions
Manual
Example XOP
Development Systems
Third Party
Data Acquistion
Cameras/Digitizers
Instruments using IGOR
Software
Developers and Consultants
Resellers
OEM Information
News & Blog
Downloads
All Downloads
Current Releases
Samples Galleries
Case Studies
Space Physics Research
Atmospheric Research
MFP3D Atomic Force Microscope
Neuromatic and NClamp
NeutroNM
Neutron Scattering
TGSGUI Optical Simulation
Wide-Angle Neutron Spin Echo Spectroscopy
ZeFir
IgorExchange Forums
All Recent Activity
General (Main) Forum
Igor Pro Wishlist Forum
News and Announcements Forum
WaveMetrics.com Forum
Code Snippets
Projects
Join the Forum (Register)
Support Center
Contact Us
FAQ
Igor Manual
Video Tutorials
Current and Legacy Versions
User Resources & Contributions
Japanese Support Center / 日本語サポートセンター
日本からのご購入について
ガイドツアー(日本語特別版)
マニュアル・日本語ビジュアル解説
各種日本語サポート情報
User account menu
Forum Log In
Submitted by Dr. E. Hasselbrink.
