copy/paste trace formatting
Does this exist somewhere? I had a quick look around and couldn't find it outside of a feature request in the wishlist forum.
#pragma ModuleName=CopyTrace
#pragma version=1.11
// if you use the marquee menu to copy trace(s) you can hold option/alt
// when clicking "paste traces" to select axes
// ------ copy/paste trace formatting ---------
menu "TracePopup", dynamic
    "Copy Trace", /Q, CopyTrace#CopyTrace(0)
    "Cut Trace", /Q, CopyTrace#CopyTrace(1)
    SelectString(cmpstr(GetScrapText()[0,5], "YWAVE:")==0, "", "Paste Trace Formatting"), /Q, CopyTrace#PasteTraceFormatting(2)
    SelectString(cmpstr(GetScrapText()[0,5], "YWAVE:")==0, "", "Paste Trace Offsets"), /Q, CopyTrace#PasteTraceFormatting(1)
menu "GraphPopup", dynamic
    SelectString(cmpstr(GetScrapText()[0,5], "YWAVE:")==0, "", "Paste Trace"), /Q, CopyTrace#PasteTrace(GetScrapText())
    SelectString(cmpstr(GetScrapText()[0,7], "MQtraces")==0, "", "Paste Traces"), /Q, CopyTrace#PasteTraces()
menu "GraphMarquee"
    "Copy Traces in Marquee", /Q, CopyTrace#CopyTraces()
    "Remove Traces in Marquee", /Q, CopyTrace#HideOrRemoveMQTraces(0)
    "Hide Traces in Marquee", /Q, CopyTrace#HideOrRemoveMQTraces(1)
    submenu "Recolour Traces in Marquee"
        "*COLORPOP*", /Q, CopyTrace#SetMQTraceColor()
    "Copy Marquee Tracenames", /Q, PutScrapText CopyTrace#TracesInMarquee()
static function CopyTrace(int cut)
    GetLastUserMenuInfo
    wave/Z w = TraceNameToWaveRef(S_graphName, S_traceName)
    if (WaveExists(w)==0)
    string s = "YWAVE:" + GetWavesDataFolder(w,4) + ";" + TraceInfo(S_graphName, S_traceName, 0)
    PutScrapText s
    if (cut)
        RemoveFromGraph/W=$S_graphName/Z $S_traceName
static function CopyTraces()
    string strTraces = TracesInMarquee()
    GetMarquee/K
    int i
    int imax = ItemsInList(strTraces)
    if (imax == 0)
    string scrap = "MQtraces\r"
    string strTrace = ""
    for (i=0;i<imax;i++)
        strTrace = StringFromList(i, strTraces)
        wave/Z w = TraceNameToWaveRef(S_marqueeWin, strTrace)
        scrap += "YWAVE:" + GetWavesDataFolder(w,4) + ";" + TraceInfo(S_marqueeWin, strTrace, 0)
    PutScrapText scrap
static function PasteTraces()
    string scrap = GetScrapText()
    int start = 0, stop = 0
    int replaceAxes = 0
    if (GetKeyState(0) & 2) // option/alt
        // choose axes
        GetLastUserMenuInfo
        string axis = "", hAxis = "", vAxis = "", flags = ""
        string strAxes = AxisList(S_graphName), hList = "bottom;top;", vList = "left;right;", type = "", info = ""
        int i, isHorizontal
        Make/D/free/N=3 wAx // free wave to hold axis minimum, maximum, axis value for mouse location
        for (i=ItemsInList(strAxes);i>=0;i--)
            axis = StringFromList(i, strAxes)
            info = AxisInfo(S_graphName, axis)
            type = StringByKey("AXTYPE", info)
            isHorizontal = (cmpstr(type, "bottom")==0 || cmpstr(type,"top")==0)
            isHorizontal = isHorizontal || (cmpstr(type[0,2],"/B=")==0 || cmpstr(type[0,2],"/T=")==0)
            GetAxis /W=$S_graphName/Q $axis
            wAx = {v_min, v_max, AxisValFromPixel(S_graphName, axis, isHorizontal ? V_mouseX : V_mouseY)}
            if (WaveMax(wAx) == wAx[2] || WaveMin(wAx) == wAx[2])
                continue
            if (isHorizontal)
                if (FindListItem(axis, hList) < 0)
                    hList = AddListItem(axis, hList)
                if (FindListItem(axis, vList) < 0)
                    vList = AddListItem(axis, vList)
        Prompt vAxis, "Vertical Axis", Popup, vList
        Prompt hAxis, "Horizontal Axis", Popup, hList
        DoPrompt "Select Axes", vAxis, hAxis
        if (V_flag || cmpstr(vAxis, "_none_") == 0 || cmpstr(hAxis, "_none_") == 0)
        if (cmpstr(hAxis, "top") == 0)
            flags += "/T"
            info = AxisInfo(S_graphName, vAxis)
            flags += StringByKey("AXFLAG", info)
        if (cmpstr(vAxis, "right") == 0)
            flags += "/R"
            info = AxisInfo(S_graphName, hAxis)
        replaceAxes = 1
    string cmd = ""
    do
        start = strsearch(scrap, "YWAVE:", stop)
        if (start<0)
        stop = strsearch(scrap, "YWAVE:", start + 1)
        stop = stop<0 ? strlen(scrap) - 1 : stop - 1
        cmd = scrap[start,stop]
        if (replaceAxes)
            cmd = ReplaceStringByKey("YAXIS", cmd, vAxis)
            cmd = ReplaceStringByKey("XAXIS", cmd, hAxis)
            cmd = ReplaceStringByKey("AXISFLAGS", cmd, flags)
        PasteTrace(cmd)
    while(1)
static function PasteTrace(string info)
    string s = "", cmd = "AppendToGraph"//, info = GetScrapText()
    cmd += StringByKey("AXISFLAGS", info, ":", ";") + " "
    cmd += StringByKey("YWAVE", info, ":", ";") + StringByKey("YRANGE", info, ":", ";")
    s = StringByKey("XWAVE", info, ":", ";")
    if (strlen(s))
        cmd += " vs " + StringByKey("XWAVEDF", info, ":", ";") + s + StringByKey("XRANGE", info, ":", ";")
    Execute cmd
    s = StringByKey("ERRORBARS", info, ":", ";")
    if (strlen(s))
        Execute s
    // figure out trace name, or trace number
    s = TraceNameList("",";",1)
    string tracename = StringFromList(ItemsInList(s)-1, s)
    // apply formatting
    s = info[strsearch(info, "RECREATION:", 0) + 11,Inf]
    int i
    int numCmd = ItemsInList(s)
    for (i=0;i<numCmd;i++)
        cmd = StringFromList(i, s)
        if (!stringmatch(cmd, "offset(x)=*"))
            Execute/Q/Z "ModifyGraph "+ReplaceString("(x)", cmd, "("+traceName+")", 0, 1)
static function PasteTraceFormatting(int WhichCmds)
    GetLastUserMenuInfo
    string s = GetScrapText(), cmd = ""
    s = s[strsearch(s, "RECREATION:", 0) + 11, Inf]
    int i
        if ((WhichCmds&1) && cmpstr(cmd[0,9], "offset(x)=")==0) // bit 0, offsets
            Execute/Q/Z "ModifyGraph " + ReplaceString("(x)", cmd, "("+S_traceName+")", 0, 1)
        elseif ((WhichCmds&2) && cmpstr(cmd[0,9], "offset(x)="))
// note that the list will be reverse-ordered, which is useful if you
// want to loop over the list to remove or change trace names.
static function/S TracesInMarquee()
    GetMarquee/Z
    string strWin = S_marqueeWin
    variable hCentre, vCentre, delX, delY
    vCentre = (v_top + v_bottom) / 2
    hCentre = (v_left + v_right) / 2
    delX = abs(v_right - v_left) / 2
    delY = abs(v_bottom - v_top) / 2
    string outlist = "", inlist = TraceNameList(strWin,";",1+4) // excludes hidden traces
    string strHit = ""
    string strOptions = ""
    int i
    int numTraces = ItemsInList(inlist)
    for (i=0;i<numTraces;i++)
        strTrace = StringFromList(i,inlist)
        sprintf strOptions, "WINDOW:%s;ONLY:%s;DELTAX:%g;DELTAY:%g;", strWin, strTrace, delX, delY
        strHit = TraceFromPixel(hCentre, vCentre, strOptions)
        if (strlen(strHit) == 0)
            continue
        outlist = AddListItem(strTrace, outlist)
    return outlist
static function SetMQTraceColor()
    GetLastUserMenuInfo // Sets V_Red, V_Green, V_Blue, V_Alpha, S_value, V_value
    GetMarquee/Z/K
    int i, imax
        ModifyGraph rgb($StringFromList(i, strTraces))=(V_Red,V_Green,V_Blue,V_Alpha)
static function HideOrRemoveMQTraces(int hide)
    GetMarquee/Z/K
    int i, imax
        if (hide)
            ModifyGraph hideTrace($StringFromList(i, strTraces))=1
            RemoveFromGraph $StringFromList(i, strTraces)
See WaveMetrics Procedures:Graph Utility Procs.ipf. Includes CopyTraceSettings(), CopyAxisSettings(), CopyImageSettings() and CopyContourSettings().
Has a number of other useful utilities related to getting characteristics of graphs.
It's pretty old. Probably could use some modern polish.
Tony, what happens if the user changed trace parameters from the command line rather than menu?
Tony's right- TraceInfo returns the current state of the data structures. Note that it can return stale info in a function because certain things are updated during drawing, a running function suppresses redrawing. If you use ModifyGraph, SetAxis, etc., in a function, call DoUpdate before TraceInfo.
In reply to by s.r.chinn
I'm realizing that I should have been more clear about how the snippet is used:
right click on a trace and select 'copy trace formatting', then right click on a different trace and select 'paste trace formatting'.
A more useful version might have options to paste offset settings separately from line/marker/color etc.
paste trace formatting, offsets, or the trace itself...
Edit: The most recent version of the code is at the top of this thread
I have added some marquee menus to allow hiding, removing, copying and pasting groups of traces.
