3D Representation of H Atom Orbitals
The following code generates different representations of the real H atom orbitals. The wave function and the wave function squared are represented as isosurfaces in different Gizmo plots. The sign of the wave function is represented by color (i.e., blue and red isosurfaces). In a different window, a Monte Carlo simulation is used to generate a probabilistic point cloud representation of the wave function. Graphs of the radial wave function are also generated.
The isosurfaces may need to be tweaked. For people not used to the Gizmo interface, this can be accomplished with the Modify Isosurface macro.
Code to generate the Bohr orbitals is also included.
Sample images are shown after the code.
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access
#pragma DefaultTab={3,20,4} // Set default tab width in Igor Pro 9 and later
// Procedures to generate 3D plots of real H wave functions orbitals
// Melissa A. Hines, Cornell University, Melissa.Hines@cornell.edu
Menu "Macros"
"Generate Bohr Orbital"
"Generate H Orbital"
"Modify Isosurface"
Proc GenerateHOrbital(n, l, m, genPointCloud)
variable n, l, m, genPointCloud
Prompt n, "n:"
Prompt l, "l:"
Prompt m, "m:"
Prompt genPointCloud, "Generate Point Cloud?", popup "Yes;No"
makeWavefunctions(0, 0, n, l, m, genPointCloud==1)
Proc GenerateBohrOrbital(n, amplitude)
variable n, amplitude=0.2
make/n=256/o circle_x, circle_y, bohrOrbital_x, bohrOrbital_y;
SetScale/I x 0,2*pi,"", circle_x,circle_y,bohrOrbital_x,bohrOrbital_y
circle_x = cos(x);circle_y = sin(x)
bohrOrbital_x = (1+amplitude*cos(n*x))*cos(x);bohrOrbital_y =(1+amplitude*cos(n*x))*sin(x)
if(strlen(WinList("bohrOrbitalGraph", ";","")) < 2)
Execute "bohrOrbitalGraph()"
Proc ModifyIsosurface(theSurface, larger, factor)
variable theSurface, larger, factor=2
Prompt theSurface, "Which isosurface?", popup "Psi;Psi2"
Prompt larger, "Which direction?", popup "Larger;Smaller"
Prompt factor, "How much?"
PauseUpdate
variable oldIsoValue, multiplier
multiplier = (larger < 2) ? 1/factor : factor
if(theSurface < 2) // Modify Psi
oldIsoValue = currentIsoValue("GizmoPsi", "posSurface")
DoWindow/F GizmoPsi
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier}
oldIsoValue = currentIsoValue("GizmoPsi2", "psi2Surface")
DoWindow/F GizmoPsi2
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier}
// Calculate H atom wavefunction using real orbitals defined at
// https://en.wikipedia.org/wiki/Atomic_orbital#Real_orbitals
Function calcPsi(n, l, m, rr, theta, phi)
variable n, l, m, rr, theta, phi
if(m < 0)
return sqrt(2)*(-1)^m * Rnl(n, l, rr) * imag(sphericalHarmonics(l,-m,theta,phi))
elseif(m > 0)
return sqrt(2)*(-1)^m * Rnl(n, l, rr) * real(sphericalHarmonics(l,m,theta,phi))
return Rnl(n, l, rr) * real(sphericalHarmonics(l,0,theta,phi))
// Calculate H atom radial wavefunction as defined at https://en.wikipedia.org/wiki/Hydrogen_atom#:~:text=The%20normalized%20position%20wavefunctions
Function Rnl(n, l, r)
variable n, l, r
variable out, a0 = 0.529, rho
rho = 2*r/n/a0
out = sqrt((2/n/a0)^3*factorial(n - l - 1)/(2 * n * factorial(n + l))) * exp(-rho/2)*(rho)^(l) * LaguerreA(n-l-1, 2*l+1, rho)
return out
// This function calculates the radial wavefunction and displays graphs of psi, psi^2, and 4 pi r^2 psi^2.
// Three dimensional waves representing psi^2 and positive and negative regions of psi are generated. These
// are displayed in Gizmo plots. The isosurfaces may need tweaking to generate a pleasing size.
// Finally (if requested) a Monte Carlo algorithm is used to generate a point cloud representing psi.
Function makeWavefunctions(pts, range, n, l, m, doMakeCloud)
// pts = number of points in sqr box. 75 seems to be a good number. Use 0 to autoscale.
// range = Box is defined over the region x, y, z = (-range, range). Use 0 to autoscale.
// n, l, m: Usual hydrogenic quantum numbers
// doMakeCloud = (0, 1) depending on whether the point cloud should be generated.
variable pts, range, n, l, m, doMakeCloud
variable i,j,k,xx,yy,zz,rr,rho,phi,theta, psi
// Validate the quantum numbers
if( (n < 1) || (l >= n) || (l < 0) || (abs(m) > l))
Print "Invalid quantum numbers"
return -1
// Autosizing if pts == 0
if(pts < 1)
pts = 75
variable center=floor(pts/2) // Use odd number of points
// Autoscaling if range == 0
if(!exists("radialPsi"))
make/n=512/o radialPsi, radialPsi2, radialProbability, zero
wave radialPsi, radialPsi2, radialProbability, zero
if(range < 0.01)
range = calcRange(150, n, l) // Set a huge range and do a rough graph
range = calcRange(range, n, l) // Refine the range
// Update radial wavefunction
SetScale/I x 0,range,"", radialPsi,radialPsi2,radialProbability,zero
radialPsi = Rnl(n,l,x)
radialPsi2 = radialPsi^2
radialProbability = 4*pi*x^2*radialPsi2
// If the radial graphs are not displayed, display them
if(strlen(WinList("radialPsiGraph", ";","")) < 2)
Execute "radialPsiGraph()"
if(strlen(WinList("radialPsi2Graph", ";","")) < 2)
Execute "radialPsi2Graph()"
if(strlen(WinList("radialProbabilityGraph", ";","")) < 2)
Execute "radialProbabilityGraph()"
pts = 2*floor(pts/2) + 1
make/o/n=(pts, pts, pts) ddd_psi2, ddd_psiPos, ddd_psiNeg
SetScale/I x -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg
SetScale/I y -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg
SetScale/I z -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg
for(k=0;k<pts;k+=1)
zz=range * (k-center)/center
for(j=0;j<pts;j+=1)
yy=range * (j-center)/center
for(i=0;i<pts;i+=1)
xx=range * (i-center)/center
// compute spherical polar coords
rr=sqrt(xx^2 + yy^2 + zz^2)
phi=atan2(yy,xx)
theta=acos(zz/rr)
psi = calcPsi(n, l, m, rr, theta, phi)
if(psi > 0)
ddd_psiPos[i][j][k] = psi
ddd_psiNeg[i][j][k] = 0
ddd_psiPos[i][j][k] = 0
ddd_psiNeg[i][j][k] = -psi
ddd_psi2[i][j][k] = psi^2
if(strlen(WinList("GizmoPsi", ";","")) < 2)
Execute "GizmoPsi()"
if(strlen(WinList("GizmoPsi2", ";","")) < 2)
Execute "GizmoPsi2()"
wavestats/q ddd_psiPos
DoWindow/F GizmoPsi
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={isoValue,V_max/5}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={isoValue,V_max/5}
wavestats/q ddd_psi2
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={isoValue,V_max/50}
if(doMakeCloud)
if(strlen(WinList("GizmoPointCloud", ";","")) > 2)
DoWindow/F GizmoPointCloud
ModifyGizmo stopUpdates
makeCloud(n, l, m, range, 30000)
ModifyGizmo resumeUpdates
Execute "GizmoPointCloud()"
wave W_coef, W_sigma
KillWaves/Z W_coef, W_sigma, scaledWave, M_colors
// Calculates an optimal range for the wavefunctions based on the outermost maximum in the radial distribution function
Function calcRange(roughRange, n, l)
variable roughRange, n, l
SetScale/I x 0,roughRange,"", radialPsi,radialPsi2,radialProbability,zero
// Fit the max in the radialProbabily to a Gaussian
wavestats/Q radialProbability
K0 = 0;K1 = V_max;K2 = V_maxLoc;
CurveFit/H="1110"/Q gauss radialProbability
wave W_coef
return ceil(W_coef[2] + 1.5 * W_coef[3])
// Returns the currently plotted isoValue for a Gizmo isosurface
Function currentIsoValue(gizmoName, isoSurfaceName)
string gizmoName, isoSurfaceName
string matchStr, theStr
variable cur = 0
GetGizmo/n=$gizmoName objectList
wave/T TW_gizmoObjectList
matchStr = "*ModifyGizmo ModifyObject="+isoSurfaceName+",objectType=isoSurface,property={ isoValue,*"
do
if(stringmatch(TW_gizmoObjectList[cur], matchStr))
theStr = TW_gizmoObjectList[cur]
theStr = theStr[strsearch(theStr, "isoValue,", 0)+9,inf]
theStr = theStr[0, strlen(theStr)-2]
KillWaves TW_gizmoObjectList
return str2num(theStr)
cur += 1
while(cur < numpnts(TW_gizmoObjectList))
return NaN
Function colorXYZ(n, l, m, xx, yy, zz)
variable n, l, m, xx, yy, zz
variable rr, phi, theta
phi=atan2(yy,xx)
theta=acos(zz/rr)
return sign(calcPsi(n, l, m, rr, theta, phi))
Function acceptOnePnt(n, l, m, xx, yy, zz, numAccepted)
variable n, l, m, xx, yy, zz, numAccepted
wave pointCloud, colorPnts
pointCloud[numAccepted][0] = xx; pointCloud[numAccepted][1] = yy; pointCloud[numAccepted][2] = zz;
colorPnts[numAccepted] = colorXYZ(n, l, m, xx, yy, zz)
numAccepted += 1
return numAccepted
Function acceptPnts(n, l, m, xx, yy, zz, numAccepted)
// Take advatage of the symmetry of the orbitals to calculate faster
numAccepted = acceptOnePnt(n, l, m, xx, yy, zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, -xx, yy, zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, xx, -yy, zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, xx, yy, -zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, -xx, -yy, zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, -xx, yy, -zz, numAccepted)
numAccepted = acceptOnePnt(n, l, m, -xx, -yy, -zz, numAccepted)
return numAccepted
// This function uses a Monte Carlo algorithm to generate a probabalistic point cloud representing the wavefunction.
// The positive and negative components of the wave function are colored red and blue, respectively.
Function makeCloud(n, l, m, range, numAccepts)
variable n, l, m, range, numAccepts
// range = Box is initiallydefined over the region x, y, z = (-range, range). Autoscales after 10% complete
variable xx, yy, zz, rr, phi, theta, numTries, numAccepted,magnitude, kMax, maxRange, rescale
numAccepts = 8 * ceil(numAccepts/8)
make/n=(numAccepts, 3)/o pointCloud
pointCloud = 0
make/o/n=(numAccepts) colorPnts
numAccepted = 0
numTries = 0
rescale = 1
// Find the maximum value of the wavefuction over the selected range
kMax = findMax(n, l, m, numAccepts, range)
// The efficiency of the algorithm depends on an optimal setting of the range variable.
// We use the input range for 10% of the tries, then reset based on the max value
// found to that point
maxRange = -1
do
xx = enoise(range); yy = enoise(range); zz = enoise(range)
phi=atan2(yy,xx)
theta=acos(zz/rr)
magnitude = calcPsi(n, l, m, rr, theta, phi)^2
if(abs(magnitude) > abs(enoise(kMax)))
numAccepted = acceptPnts(n, l, m, xx, yy, zz, numAccepted)
if(rescale && max(xx, yy, zz) > maxRange)
maxRange = max(xx, yy, zz)
numTries += 1
if(rescale && numAccepted > 0.1 * numAccepts)
range = maxRange * 1.15
rescale = 0
print "New range =", range
while(numAccepted < numAccepts)
// To create a color wave for a scatter in Gizmo
ColorTab2Wave Rainbow
wave M_colors
duplicate/o colorPnts, scaledWave
Variable theMin=WaveMin(scaledWave)
Variable theMax=WaveMax(scaledWave)
Variable nor=(DimSize(M_colors,0)-1)/2
MatrixOP/O scaledWave=nor*(scaledWave-theMin)
M_colors/=65535
make/o/n=(numAccepts,4) colorWave=1 // alpha will be 1.
colorWave[][0]= M_colors[scaledWave[p]][0]
colorWave[][1]= M_colors[scaledWave[p]][1]
colorWave[][2]= M_colors[scaledWave[p]][2]
// If calculating radialPsi^2, the following line should be approx 1
//print "The integral is ", numAccepted/numTries * 8 * range^3 * kMax
// print numTries, numAccepted
Function findMax(n, l, m, numTries, range)
variable n, l, m, numTries, range
variable theMax = 0, cnt = 0, xx, yy, zz, rr, phi, theta, magnitude
do
phi=atan2(yy,xx)
theta=acos(zz/rr)
magnitude = abs(calcPsi(n, l, m, rr, theta, phi))
if(magnitude > theMax)
theMax = magnitude
cnt += 1
while(cnt < numTries)
return theMax
Window GizmoPsi() : GizmoPlot
PauseUpdate; Silent 1 // building window...
// Building Gizmo 9 window...
NewGizmo/W=(35,40,550,500)
ModifyGizmo startRecMacro=901
ModifyGizmo scalingOption=63
AppendToGizmo isoSurface=root:ddd_psiPos,name=posSurface
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ surfaceColorType,0}
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineColorType,0}
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineWidthType,0}
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ fillMode,2}
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineWidth,1}
ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ isoValue,0.01}
ModifyGizmo modifyObject=posSurface,objectType=Surface,property={calcNormals,1}
ModifyGizmo setObjectAttribute={posSurface,diffusePos}
ModifyGizmo setObjectAttribute={posSurface,shininess0}
ModifyGizmo setObjectAttribute={posSurface,specular}
AppendToGizmo Axes=boxAxes,name=axes0
ModifyGizmo ModifyObject=axes0,objectType=Axes,property={-1,axisScalingMode,1}
ModifyGizmo ModifyObject=axes0,objectType=Axes,property={0,ticks,3}
ModifyGizmo ModifyObject=axes0,objectType=Axes,property={1,ticks,3}
ModifyGizmo ModifyObject=axes0,objectType=Axes,property={2,ticks,3}
ModifyGizmo modifyObject=axes0,objectType=Axes,property={-1,Clipped,0}
AppendToGizmo isoSurface=root:ddd_psiNeg,name=negSurface
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ surfaceColorType,0}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineColorType,0}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineWidthType,0}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ fillMode,2}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineWidth,1}
ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ isoValue,0.01}
ModifyGizmo modifyObject=negSurface,objectType=Surface,property={calcNormals,1}
ModifyGizmo setObjectAttribute={negSurface,diffuseNeg}
ModifyGizmo setObjectAttribute={negSurface,shininess0}
ModifyGizmo setObjectAttribute={negSurface,specular}
AppendToGizmo freeAxesCue={0,0,0,1},name=freeAxesCue0
ModifyGizmo modifyObject=freeAxesCue0,objectType=freeAxisCue,property={colorType,0}
AppendToGizmo light=Directional,name=light0
ModifyGizmo modifyObject=light0,objectType=light,property={ position,-0.184655,-0.414741,0.891007,0.000000}
ModifyGizmo modifyObject=light0,objectType=light,property={ direction,-0.184655,-0.414741,0.891007}
ModifyGizmo modifyObject=light0,objectType=light,property={ specular,1.000000,1.000000,1.000000,1.000000}
AppendToGizmo attribute diffuse={1,0,0,1,1032},name=diffusePos
AppendToGizmo attribute diffuse={1.5259e-05,0.244434,1,1,1032},name=diffuseNeg
AppendToGizmo attribute shininess={42,42},name=shininess0
AppendToGizmo attribute specular={1,1,1,1,1032},name=specular
ModifyGizmo setDisplayList=0, object=freeAxesCue0
ModifyGizmo setDisplayList=1, object=light0
ModifyGizmo setDisplayList=2, object=posSurface
ModifyGizmo setDisplayList=3, object=negSurface
ModifyGizmo autoscaling=1
ModifyGizmo currentGroupObject=""
ShowTools
ModifyGizmo showInfo
ModifyGizmo infoWindow={551,31,1185,418}
ModifyGizmo SETQUATERNION={0.000000,-0.000000,0.000000,1.000000}
ModifyGizmo endRecMacro
Execute/Q/Z "SetWindow kwTopWin sizeLimit={46,234,inf,inf}" // sizeLimit requires Igor 7 or later
EndMacro
Window GizmoPsi2() : GizmoPlot
NewGizmo/W=(213,605,728,1065)
AppendToGizmo isoSurface=root:ddd_psi2,name=psi2Surface
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ surfaceColorType,0}
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineColorType,0}
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineWidthType,0}
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ fillMode,2}
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineWidth,1}
ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ isoValue,0.000225374}
ModifyGizmo modifyObject=psi2Surface,objectType=Surface,property={calcNormals,1}
ModifyGizmo setObjectAttribute={psi2Surface,diffuse}
ModifyGizmo setObjectAttribute={psi2Surface,specular}
ModifyGizmo setObjectAttribute={psi2Surface,shininess}
ModifyGizmo modifyObject=light0,objectType=light,property={ position,0.294889,0.694714,0.656059,0.000000}
ModifyGizmo modifyObject=light0,objectType=light,property={ direction,0.294889,0.694714,0.656059}
AppendToGizmo attribute diffuse={1,0.250019,0.250019,1,1032},name=diffuse
AppendToGizmo attribute specular={1,1,0,1,1032},name=specular
AppendToGizmo attribute shininess={30,30},name=shininess
ModifyGizmo setDisplayList=2, object=psi2Surface
ModifyGizmo setDisplayList=3, opName=clearColor0, operation=clearColor, data={1,1,1,1}
ShowTools
ModifyGizmo infoWindow={782,750,1405,1094}
ModifyGizmo SETQUATERNION={0.000000,0.000000,0.000000,1.000000}
EndMacro
Window GizmoPointCloud() : GizmoPlot
NewGizmo/W=(947,721,1512,1219)
AppendToGizmo Scatter=root:pointCloud,name=thePoints
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ scatterColorType,1}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ markerType,0}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ sizeType,0}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ rotationType,0}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ Shape,2}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ size,0.05}
ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ colorWave,root:colorWave}
ModifyGizmo setDisplayList=1, object=thePoints
ShowTools
ModifyGizmo infoWindow={804,539,1398,783}
ModifyGizmo SETQUATERNION={-0.080336,0.084591,0.010790,0.993114}
EndMacro
Window radialPsiGraph() : Graph
Display /W=(4,523,399,731) radialPsi,zero
ModifyGraph gFont="Helvetica"
ModifyGraph lStyle(zero)=1
ModifyGraph rgb=(0,0,0)
ModifyGraph mirror=2
ModifyGraph nticks(left)=0
ModifyGraph font="Helvetica"
ModifyGraph fSize=12
ModifyGraph lblMargin(left)=11
ModifyGraph lblLatPos(left)=-1
ModifyGraph btLen=4
Label left "ψ"
Label bottom "\\f02r\\f00 (Å)"
EndMacro
Window radialPsi2Graph() : Graph
Display /W=(0,771,395,979) radialPsi2
ModifyGraph lblMargin(left)=10
ModifyGraph btLen=4
Label left "ψ\\S2\\M"
EndMacro
Window radialProbabilityGraph() : Graph
Display /W=(1,1015,396,1223) radialProbability
ModifyGraph fSize=14
ModifyGraph btLen=4
Label left "4 π \\f02r\\f00\\S2\\M ψ\\S2\\M"
EndMacro
Window bohrOrbitalGraph() : Graph
Display /W=(35,520,424,903) circle_y vs circle_x
AppendToGraph bohrOrbital_y vs bohrOrbital_x
ModifyGraph gFont="Helvetica",height={Plan,1,left,bottom}
ModifyGraph lStyle(circle_y)=1
ModifyGraph nticks=0
ModifyGraph axThick=0
EndMacro
