Custom Markers: Half filled circles
Function CirclesMarkerProc(s) STRUCT WMMarkerHookStruct &s if( s.marker > 3 ) return 0 endif Variable size= s.size-s.penThick/2 if( s.opaque ) SetDrawEnv linethick=0,fillpat=-1 DrawRect s.x-size,s.y-size,s.x+size,s.y+size SetDrawEnv linethick=s.penThick endif switch(s.marker) case 0: // Up SetDrawEnv linethick=s.penThick, fillpat=1,fillfgc= (s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue), linefgc=(s.penRGB.red,s.penRGB.green,s.penRGB.blue) DrawOval s.x-size,s.y-size,s.x+size,s.y+size SetDrawEnv fillfgc= (65535,65535,65535),linefgc=(s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue) DrawArc s.x,s.y,size-s.penThick,0,180 Break case 1: //Right SetDrawEnv linethick=s.penThick, fillpat=1,fillfgc= (s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue), linefgc=(s.penRGB.red,s.penRGB.green,s.penRGB.blue) DrawOval s.x-size,s.y-size,s.x+size,s.y+size SetDrawEnv fillfgc= (65535,65535,65535),linefgc=(s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue) DrawArc s.x,s.y,size-s.penThick,-90,90 Break case 2: // Bottom SetDrawEnv linethick=s.penThick, fillpat=1,fillfgc= (s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue), linefgc=(s.penRGB.red,s.penRGB.green,s.penRGB.blue) DrawOval s.x-size,s.y-size,s.x+size,s.y+size SetDrawEnv fillfgc= (65535,65535,65535),linefgc=(s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue) DrawArc s.x,s.y,size-s.penThick,180,0 Break case 3: //left SetDrawEnv linethick=s.penThick, fillpat=1,fillfgc= (s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue), linefgc=(s.penRGB.red,s.penRGB.green,s.penRGB.blue) DrawOval s.x-size,s.y-size,s.x+size,s.y+size SetDrawEnv fillfgc= (65535,65535,65535),linefgc=(s.mrkRGB.red,s.mrkRGB.green,s.mrkRGB.blue) DrawArc s.x,s.y,size-s.penThick,90,-90 Break endswitch return 1 End
The graph procedure is exactly the same as the one provided in the Advanced topics section
Window Graph1() : Graph PauseUpdate; Silent 1 // building window... Make/O/N=10 testw=sin(x) Display /W=(35,44,430,252) testw,testw,testw,testw ModifyGraph offset(testw#1)={0,-0.2},offset(testw#2)={0,-0.4},offset(testw#3)={0,-0.6} ModifyGraph mode=3,marker(testw)=100,marker(testw#1)=101,marker(testw#2)=102,marker(testw#3)=103 SetWindow kwTopWin,markerHook={CirclesMarkerProc,100,103} EndMacro
