MovieMaker
A small procedure that allows you to make movies out of a set of 2D waves.
How to use:
1- Drag drop the procedure file onto igor and compile
2- Run "Load Panel" from the MovieMaker menu
3- Click on Test Waves to make some test waves to play with
4- Click on Preview. Make adjustments, add annotations etc. add extra commands (if any) in command boxes to run on frames.
5- Run through frames using the slider
6- Click on "Make" to export the video
notes: all the adjustments are saved inside the "MovieMaker" folder. This means that if you save the experiment, your adjustments to the preview frame will not be lost.
How to use:
MovieMaker IGOR.6.30.x-1.0-0
Release File: | MovieMaker.ipf (5.88 KB) |
Version: | IGOR.6.30.x-1.0-0 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 0 |
Release Notes: | initial release. |
