WaveList based on a range of number
Dear all,
I'd like to make (and display) a list of waves based on the range of integers (suffix) in the wave name:
say, the names of my waves are as follows: "test_a4_350", "test_a4_351", "test_a4_352", ..., "test_a4_850".
How can I make a list of wavenames that includes only waves from "test_a4_380" to "test_a4_450"?
Thanks very much!
jtigor
The following code is not very elegant, but should do the job. Following your example, call it using
ListOfWaves(380, 450)
to get a string list of wave names ending in values from 380 to 450 and including the end points.
//vMin & vMax are the min and max suffix values marking wave names to retain
//outputs a string list (semicolon separated) of wave names with suffixes matching vMin & vMax
Function/S ListOfwaves(vMin, vMax)
	Variable vMin
	Variable vMax
	Variable vIndex = 0
	Variable vSuffix = 0
	Variable vNumItems = 0
	Variable vStrLength
	String sFullList = ""
	String sEditedList = ""
	String sListItem = ""
	sFullList = WaveList("*", ";", "" )
	vNumItems = ItemsInList(sFullList, ";")
	for( vIndex = 0; vIndex < ItemsInList(sFullList, ";"); vIndex += 1)
		sListItem = StringFromList(vIndex, sFullList, ";")
		vStrLength = strlen( sListItem )
		vSuffix = str2num( sListItem[vStrLength - 4, vStrLength - 1] )
		if( vSuffix >= vMin && vSuffix <= vMax)
			sEditedList += sListItem + ";"
	return sEditedList
kanekaka
Function/S ListOfWaves(baseName, vMin, vMax)
	String baseName
	Variable vMin, vMax
	Variable vIndex = 0
	String sEditedList = "", sListItem
	for( vIndex = vMin; vIndex <= vMax; vIndex += 1)
		sprintf sListItem, "%s%d", baseName, vIndex
		if (exists(sListItem) == 1)
	return sEditedList
ListOfWaves("test_a4_", 380, 450)
xhou
Dear jtigor and kanekaka,
Your codes definitely solved my problem! Thanks so much for your generosity and wisdom. I also learned a bit about how to optimize my igor code from reading yours.
jtigor
xhou,
One other thing to keep in mind is that both functions operate only on the current folder.
I like kanekaka's solution... a good example of thinking outside the box.
