Proper titles for wave columns
My code does the job I want it to do, but it would help with the visualization of the data that it produces if I could modifiy the title of the wave columns. My complete code creates several waves in the root folder and then files these with data. The number of columns in each of these root waves is determined by the number of data folders (present in the root folder) which I want the code to work on.
I have a vastly simplified version of my code below. How would I modify the NiceColumnNames function so that instead of getting three columns all named 'PeakAmplitudes', I get three columns named: 'CG1', 'CG2' and 'CG3'?
Function MakeDFs()
	NewDataFolder/O root:CG1
	NewDataFolder/O root:CG2
	NewDataFolder/O root:CG3
	NewDataFolder/O root:Junk
Function NiceColumnNames (vTPWaveNrB4exp)
	Variable vTPWaveNrB4exp
	Variable vTotalNrOfDFs  = CountObjectsDFR(root:, 4)
	Variable vIndex
	Variable vCounter
	Variable vNrOfDFs
	for (vIndex = 0; vIndex < vTotalNrOfDFs; vIndex += 1)
		String sDFinRoot = GetIndexedObjNameDFR(root:, 4, vIndex)
		Variable vMatch = StringMatch(sDFinRoot,"CG*")
		if (vMatch == 1)
			vNrOfDFs = vNrOfDFs + 1
		Make/O/N=(vTPWaveNrB4exp*2+5, vNrOfDFs) PeakAmplitudes = NaN
hrodstein
I think you want to use dimension labels. Here is an example:
Make/N=(5,3) test
Edit test
AppendToTable test.ld           // Append dimension labels to table
SetDimLabel 1, 0, First, test
SetDimLabel 1, 1, Second, test
SetDimLabel 1, 2, Third, test
For details execute:
DisplayHelpTopic "Dimension Labels"
Unfortunately, there is no way to show the horizontal dimension labels while hiding the horizontal dimension labels.
Another approach is to use table column titles. For example:
Make/O/N=(5,3) test
Edit test
ModifyTable title[1] = "First"
ModifyTable title[2] = "Second"
ModifyTable title[3] = "Third"
DisplayHelpTopic "Column Titles
