Workaround if "line too long"?
Is there any possibility to implement this assignment?
Make /T /N=64 Codons={"GGG","GGA","GGT","GGC","GAG","GAA","GAT","GAC","GTG","GTA","GTT","GTC","GCG","GCA","GCT","GCC","AGG","AGA","AGT","AGC","AAG","AAA","AAT","AAC","ATG","ATA","ATT","ATC","ACG","ACA","ACT","ACC","TGG","TGA","TGT","TGC","TAG","TAA","TAT","TAC","TTG","TTA","TTT","TTC","TCG","TCA","TCT","TCC","CGG",
"CGA","CGT","CGC","CAG","CAA","CAT","CAC","CTG","CTA","CTT","CTC","CCG","CCA","CCT","CCC"}
Thanks in advance :)
Best regards,
Peter
sjr51
You could do them in two parts and concatenate
Make /T /N=32 Codons1={"GGG","GGA","GGT","GGC","GAG","GAA","GAT","GAC","GTG","GTA","GTT","GTC","GCG","GCA","GCT","GCC","AGG","AGA","AGT","AGC","AAG","AAA","AAT","AAC","ATG","ATA","ATT","ATC","ACG","ACA","ACT","ACC"}
Make /T /N=32 Codons2={"TGG","TGA","TGT","TGC","TAG","TAA","TAT","TAC","TTG","TTA","TTT","TTC","TCG","TCA","TCT","TCC","CGG","CGA","CGT","CGC","CAG","CAA","CAT","CAC","CTG","CTA","CTT","CTC","CCG","CCA","CCT","CCC"}
Concatenate /NP {Codons1,Codons2}, Codons
johnweeks
There's another way, using a little-know feature of wave assignments using curly braces:
Make /T Codons={"GGG","GGA","GGT","GGC","GAG","GAA","GAT","GAC","GTG","GTA","GTT","GTC","GCG","GCA","GCT","GCC","AGG","AGA","AGT","AGC","AAG","AAA","AAT","AAC","ATG","ATA","ATT","ATC","ACG","ACA","ACT","ACC"}
Codons[32] = {"TGG","TGA","TGT","TGC","TAG","TAA","TAT","TAC","TTG","TTA","TTT","TTC","TCG","TCA","TCT","TCC","CGG","CGA","CGT","CGC","CAG","CAA","CAT","CAC","CTG","CTA","CTT","CTC","CCG","CCA","CCT","CCC"}
Generalizing this makes it possible to make the lines even shorter and more readable:
Make /O/T Codons={"GGG","GGA","GGT","GGC","GAG","GAA","GAT","GAC","GTG","GTA","GTT","GTC","GCG","GCA","GCT","GCC"}
Codons[16] = {"AGG","AGA","AGT","AGC","AAG","AAA","AAT","AAC","ATG","ATA","ATT","ATC","ACG","ACA","ACT","ACC"}
Codons[32] = {"TGG","TGA","TGT","TGC","TAG","TAA","TAT","TAC","TTG","TTA","TTT","TTC","TCG","TCA","TCT","TCC"}
Codons[48] = {"CGG","CGA","CGT","CGC","CAG","CAA","CAT","CAC","CTG","CTA","CTT","CTC","CCG","CCA","CCT","CCC"}
You can read about it here:
DisplayHelpTopic " Lists of Values"
