Extracting metadata from .dm3 files
daggaz
Wed, 11/19/2014 - 05:58 am
Advice/tips much appreciated. Thanks.
EDIT: dm3 is a file format used by Gatan Digital Micrograph and are common in the microscopy world. Its basically a tiff with some metadata tucked in. I threw in an example file (its soot imaged with HRTEM if anybody is curious), need to rename it from .jpg to .dm3 as I couldnt upload it otherwise.
Here igor always complains with "out of memory" if I try to load your file (renamed to tiff before).
November 20, 2014 at 03:51 am - Permalink
November 20, 2014 at 04:59 am - Permalink
November 20, 2014 at 12:45 pm - Permalink
November 21, 2014 at 12:31 am - Permalink
No guarantees that this is right.. but it should help you get something. Maybe someone can tidy up the code and make it more robust.
The meta data is put into a Notebook. I have suppressed the image data itself being put there.
Hope this helps,
Kurt
Code as follows:
Function LoadDM3()
// User selects DM3 file
// opens DM3 file
// starts to read data from the file
variable vRefNum
string sFileOpenMessage="Select a DM3 file"
string sFileFilter="DM3 files (*.dm3):.dm3;All Files:.*.*;"
Open/R/Z=2/F=sFileFilter/M=sFileOpenMessage vRefNum
// keep data from file open
variable vErr=V_flag
string sFullName=S_fileName
string sCleanFileName=CleanUpName(ParseFilePath(3, sFullName, ":", 0, 0),0)
if (vErr == -1)
return -1 // User cancelled.
if (vErr != 0)
return vErr
variable/G gvLayer=0 // indent or nested group layer
variable/G gvPrintData=1 // =1 to allow printing of data, 0 to forbid (eg image data itself)
NewNotebook/F=0/N=NBFileData
LoadDM3NBSetData("Loading data from "+sFullName)
string sData
variable vData
// start reading data from the file
do
// image file version
FBinRead/B=2/F=3 vRefNum,vData // big-endian, 4 bytes
if(vData!=3) // should be 3
LoadDM3NBSetData("Error in file format (version)")
break
// number of bytes in file
variable vNumBytes = vData
LoadDM3NBSetData("Root tag directory size: "+num2str(vData))
// byte order of tag data
variable/G gvByteOrder // this will be the code in FBinRead/B=(gvByteOrder)
if(vData==0) // big-endian
gvByteOrder=2
LoadDM3NBSetData("Data byte order: big-endian")
elseif(vData==1) // little-endian
gvByteOrder=3
LoadDM3NBSetData("Data byte order: little-endian")
LoadDM3NBSetData("Error in file format (byte order)")
break
// Tag Group
LoadDM3TagGroup(vRefNum)
break
while(1)
FStatus vRefNum
if(V_flag!=0) // is valid
Close vRefNum // Close the file.
return vErr // Zero signifies no error.
Function LoadDM3NBSetData(sData)
string sData
NVAR gvLayer
NVAR gvPrintData
if(gvPrintData)
sData=padstring("",gvLayer*2,0x20)+sData+"\r"
Notebook NBFileData setData=sData
Function LoadDM3TagGroup(vRefNum)
variable vRefNum
// loads a DM3 file Tag Group
NVAR gvLayer
variable vFlag
variable vData
gvLayer+=1
// is this group sorted?
FBinRead/F=1 vRefNum,vData // 1 byte
variable vGroupSorted
vGroupSorted=vData
LoadDM3NBSetData("Tag Group Sorted = "+num2str(vGroupSorted))
// is this group open?
variable vGroupOpen
vGroupOpen=vData
LoadDM3NBSetData("Tag Group Open = "+num2str(vGroupOpen))
// number of tags in group
variable vNumTags
vNumTags=vData
LoadDM3NBSetData("Number of tags in this group = "+num2str(vNumTags))
// tag entries
variable vTags
for(vTags=0;vTags<vNumTags;vTags+=1)
vFlag=LoadDM3TagEntry(vRefNum)
if(vFlag!=0) // had an error
return -1
endfor // vTags
gvLayer-=1
Function LoadDM3TagEntry(vRefNum)
variable vRefNum
// loads a DM3 file Tag Entry
NVAR gvLayer
variable vFlag
variable vData
string sData
// Tag type
variable vTagType
vTagType=vData // 21 = data, 20 = group
if(vTagType==21) // data - TagType
LoadDM3NBSetData("Tag type: 21 (Data)")
elseif(vTagType==20) // Group
LoadDM3NBSetData("Tag type: 20 (Group)")
elseif(vTagType==0) // end of file
LoadDM3NBSetData("End of file.")
return -1
LoadDM3NBSetData("Error: Tag type.")
return -1
// Tag label length
FBinRead/B=2/F=2 vRefNum,vData // 2 bytes
variable vTagLabelLength
vTagLabelLength=vData
// Tag label
if(vTagLabelLength==0) // zero length
sData="_no label_"
FReadLine/N=(vTagLabelLength) vRefNum, sData
LoadDM3NBSetData("Tag Label: "+sData)
NVAR gvPrintData
if(cmpStr(sData,"Data")==0)
gvPrintData=0 // forbid printing data
gvPrintData=1 // allow printing data
// Tag instance
vFlag=LoadDM3TagType(vRefNum)
if(vFlag!=0)
return -1
vFlag=LoadDM3TagGroup(vRefNum) // note: this is recursive
if(vFlag!=0)
return -1
Function LoadDM3TagType(vRefNum) // tag data
variable vRefNum
string sData
variable vData
NVAR gvLayer
FReadLine/N=(4) vRefNum, sData
if(cmpstr(sData,"%%%%")!=0)
LoadDM3NBSetData("Error in Tag (expected %%%%).")
return -1
// length of encoded type definition
FBinRead/B=2/F=3 vRefNum,vData // 4 bytes
// for a simple type this will = 1,
// for a string this will = 2,
// an array of a simple type will = 3,
// structs have 1+2*f where f=number of fields in struct
variable vDefinitionLength=vData
// encoded type info
make/FREE/O/I/N=(vDefinitionLength) wEncodingType // 4-byte wave
FBinRead/B=2/F=3 vRefNum,wEncodingType
variable vIndex,vIndex2,vDataType,vSize
switch(vDefinitionLength)
case 1: // simple type
LoadDM3EncodedType(vRefNum,wEncodingType[0],wEncodingType)
break
case 2: // string type
LoadDM3EncodedType(vRefNum,vData,wEncodingType)
break
case 3: // array of simple type
// wEncodingType[0]=20 - array
// wEncodingType[1]= tag data type for array members
// wEncodingType[2]= size of array
LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")
for(vIndex=0;vIndex<wEncodingType[2];vIndex+=1) // loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[1],wEncodingType)
endfor // vIndex
break
default: // struct or array type
switch(wEncodingType[0])
case 15: // struct type
// wEncodingType[0]=15 - group
// wEncodingType[1]=0 - usually
// wEncodingType[2]= number fields
// wEncodingType[3+field*2]= length field name =0
// wEncodingType[4+field*2]= tag data type for value[field]
LoadDM3NBSetData("Struct Data ("+num2str(wEncodingType[2])+")")
LoadDM3EncodedType(vRefNum,wEncodingType[4+vIndex*2],wEncodingType)
endfor // vIndex
break
case 20: // array of structs type
// wEncodingType[1]=15 - group
// wEncodingType[2]=0 - (group name) usually
// wEncodingType[3]=number of entries in struct (field)
// wEncodingType[4+field*2]= length field name =0
// wEncodingType[5+field*2]= tag data type for value[field]
// wEncodingType[...]
// wEncodingType[last]= size of array (i.e. number of repeats of struct)
for(vIndex2=0;vIndex2<wEncodingType[DimSize(wEncodingType,0)-1];vIndex2+=1) // loop round array
for(vIndex=0;vIndex<wEncodingType[3];vIndex+=1) // loop round fields
LoadDM3EncodedType(vRefNum,wEncodingType[5+vIndex*2],wEncodingType)
endfor // vIndex
endfor // vIndex2
break
endSwitch
endSwitch
Function LoadDM3EncodedType(vRefNum,vEncodingType,wEncodingType)
variable vRefNum
variable vEncodingType
wave wEncodingType
variable vData, vIndex
string sData
NVAR gvByteOrder
NVAR gvLayer
switch(vEncodingType)
case 2: // short
FBinRead/B=(gvByteOrder)/f=2 vRefNum,vData
LoadDM3NBSetData("Short data: "+num2str(vData))
break
case 3: // long
FBinRead/B=(gvByteOrder)/f=3 vRefNum,vData
LoadDM3NBSetData("Long data: "+num2str(vData))
break
case 4: // ushort
FBinRead/B=(gvByteOrder)/f=2/U vRefNum,vData
LoadDM3NBSetData("UShort data: "+num2str(vData))
break
case 5: // ulong
FBinRead/B=(gvByteOrder)/f=3/U vRefNum,vData
LoadDM3NBSetData("ULong data: "+num2str(vData))
break
case 6: // float
FBinRead/B=(gvByteOrder)/f=4 vRefNum,vData
LoadDM3NBSetData("Float data: "+num2str(vData))
break
case 7: //double
FBinRead/B=(gvByteOrder)/f=5 vRefNum,vData
LoadDM3NBSetData("Double data: "+num2str(vData))
break
case 8: // boolean
LoadDM3NBSetData("Boolean data = "+num2str(vData))
break
case 9: // char
FReadLine/N=(1) vRefNum, sData
LoadDM3NBSetData("Char data = "+sData)
break
case 10: // octet
LoadDM3NBSetData("Octet data = "+num2str(vData))
break
case 15: // struct
break
case 18: // string
for(vIndex=0;vIndex<wEncodingType[1];vIndex+=1) // loop round string length
LoadDM3NBSetData("Unicode string data = "+num2str(vData)+ " ("+num2char(vData)+")")
break
case 20: // array
break
endSwitch
November 21, 2014 at 01:16 am - Permalink
I had almost given up on this, and got distracted by work for some time, only to come back and find all this great help. I was otherwise looking at doing this manually for several hundred images (and that is just one week's work).
I love these forums, really.
EDIT: Acquisition time is given as the ushort data (all the meta data is provided in the raw format), I've decoded the following
0-9 = 48-57
: = 58
space = 32
P = 80
M = 77
A should follow from this to be equal to 65 (77 - 12)
Now to hijack this script so that it pulls this out from a group of files, translates it and writes it to a wave. Fun fun =)
May 5, 2015 at 05:20 am - Permalink
Is it possible to search the entire open file for a specific string and then get that string position? This would be significantly faster, I imagine.
Here is the modified code if anybody wants to use it. Its ugly after I got done with it.
//Notebook function now commented out
Function extract_timestamps()
string list_dm3_files, prompt_alert,file_name
variable num_files
variable/G i
//prompt for path to data folder
newpath/o dm3_data_folder
pathinfo dm3_data_folder
// load file names into string, sorting appropriately
list_dm3_files = IndexedFile(dm3_data_folder, -1, ".dm3")
// Sort using combined alpha and numeric sort
list_dm3_files = SortList(list_dm3_files, ";", 16)
//print list_dm3_files
num_files = itemsinlist(list_dm3_files)
if(num_files == 0)
prompt_alert = "Could not find any DM3 data files in the chosen folder"
doAlert 0, prompt_alert
//make an output wave to store timestamps
make/o/d/n=(num_files) timestamps
// cycle through each file, one at a time
for(i=0;i<num_files;i+=1)
file_name = stringfromlist(i,list_dm3_files)
LoadDM3(file_name)
appendtotable timestamps
modifytable format(timestamps) = 7
SetScale d 0,0,"dat", timestamps
Function LoadDM3(file_name)
string file_name
variable vRefNum
Open/R/Z=2/P=dm3_data_folder vRefNum as file_name
// opens DM3 file
//variable vRefNum
//string sFileOpenMessage="Select a DM3 file"
//string sFileFilter="DM3 files (*.dm3):.dm3;All Files:.*.*;"
//Open/R/Z=2/F=sFileFilter/M=sFileOpenMessage vRefNum
//variable vErr=V_flag
//string sFullName=S_fileName
//string sCleanFileName=CleanUpName(ParseFilePath(3, sFullName, ":", 0, 0),0)
//if (vErr == -1)
// return -1 // User cancelled.
//endif
//if (vErr != 0)
// return vErr
//endif
//NewNotebook/F=0/N=NBFileData
//LoadDM3NBSetData("Loading data from "+sFullName)
string sData
variable vData
do
//LoadDM3NBSetData("Error in file format (version)")
break
//LoadDM3NBSetData("Root tag directory size: "+num2str(vData))
gvByteOrder=2
//LoadDM3NBSetData("Data byte order: big-endian")
gvByteOrder=3
//LoadDM3NBSetData("Data byte order: little-endian")
//LoadDM3NBSetData("Error in file format (byte order)")
break
// Tag Group
break
while(1)
FStatus vRefNum
string sData
NVAR gvLayer
NVAR gvPrintData
if(gvPrintData)
//Notebook NBFileData setData=sData
variable vRefNum
NVAR gvLayer
variable vFlag
variable vData
gvLayer+=1
vGroupSorted=vData
//LoadDM3NBSetData("Tag Group Sorted = "+num2str(vGroupSorted))
variable vGroupOpen
vGroupOpen=vData
//LoadDM3NBSetData("Tag Group Open = "+num2str(vGroupOpen))
variable vNumTags
vNumTags=vData
//LoadDM3NBSetData("Number of tags in this group = "+num2str(vNumTags))
// tag entries
variable vTags
return -1
endfor // vTags
gvLayer-=1
variable vRefNum
NVAR gvLayer
variable vFlag
variable vData
string sData
// Tag type
variable vTagType
//LoadDM3NBSetData("Tag type: 21 (Data)")
//LoadDM3NBSetData("Tag type: 20 (Group)")
//LoadDM3NBSetData("End of file.")
return -1
//LoadDM3NBSetData("Error: Tag type.")
return -1
// Tag label length
// Tag label
sData="_no label_"
// EDIT of original code, introducing case for exporting data directly into IGOR
if(cmpStr(sData, "Acquisition Time")==0)
//read 5x to move to correct position
//read actual timestamp data
wave timestamps
Nvar gvByteOrder,i
variable byte_num,hours,minutes,seconds,total_seconds
variable timestampLength
string timepiece
string timestamp
FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the first piece
//print vData
vData -= 48 // translates from unsigned short data format
timepiece = num2str(vData)
timestamp = timepiece
FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the second piece
//print vData
vData -= 48
if (vData != 10) // check for the semi-colon and describe length of stamp
timestampLength = 6
timepiece = ":"
timestampLength = 5
timestamp = timestamp + timepiece
for(byte_num=0;byte_num<timestampLength;byte_num+=1)
FBinRead/B=(gvByteOrder)/f=2/U vRefNum, vData // read the rest of it
//print vData
vData -= 48
timepiece = ":"
print "The timestamp is :", timestamp
hours = str2num(StringFromList(0, timestamp ,":"))
// set 1 pm - 7 pm to military hours
if (hours < 8)
hours += 12
total_seconds = hours * 3600
minutes = str2num(StringFromList(1,timestamp,":"))
total_seconds += minutes*60
seconds = str2num(StringFromList(2,timestamp,":"))
total_seconds += seconds
timestamps[i] = total_seconds
// continue with normal code
NVAR gvPrintData
// Tag instance
if(vFlag!=0)
return -1
if(vFlag!=0)
return -1
endif // End of the introduced case see above
variable vRefNum
string sData
variable vData
NVAR gvLayer
//LoadDM3NBSetData("Error in Tag (expected %%%%).")
return -1
break
break
//LoadDM3NBSetData("Array Data ("+num2str(wEncodingType[2])+")")
endfor // vIndex
break
//LoadDM3NBSetData("Struct Data ("+num2str(wEncodingType[2])+")")
endfor // vIndex
break
endfor // vIndex
endfor // vIndex2
break
endSwitch
endSwitch
variable vRefNum
wave wEncodingType
string sData
NVAR gvByteOrder
NVAR gvLayer
case 2: // short
//LoadDM3NBSetData("Short data: "+num2str(vData))
break
case 3: // long
//LoadDM3NBSetData("Long data: "+num2str(vData))
break
case 4: // ushort
//LoadDM3NBSetData("UShort data: "+num2str(vData))
break
case 5: // ulong
//LoadDM3NBSetData("ULong data: "+num2str(vData))
break
case 6: // float
//LoadDM3NBSetData("Float data: "+num2str(vData))
break
case 7: //double
//LoadDM3NBSetData("Double data: "+num2str(vData))
break
case 8: // boolean
//LoadDM3NBSetData("Boolean data = "+num2str(vData))
break
case 9: // char
//LoadDM3NBSetData("Char data = "+sData)
break
case 10: // octet
//LoadDM3NBSetData("Octet data = "+num2str(vData))
break
case 15: // struct
break
case 18: // string
//LoadDM3NBSetData("Unicode string data = "+num2str(vData)+ " ("+num2char(vData)+")")
break
case 20: // array
break
endSwitch
May 13, 2015 at 05:44 am - Permalink
Just a thought - you could use
FStatus
to find the length of the file, then usePadString
andFBinRead
to read the entire file into a string variable. Then finally search this for your specific string usingstrsearch
.I don't know whether this would be faster.
HTH,
Kurt
May 13, 2015 at 11:43 pm - Permalink
May 18, 2015 at 12:13 am - Permalink
