Actually, I try to separate the wind direction into its two basic components. The nort-south and the east-west. Anyway, I want, if I know the tan(φ), to find the angle φ. Unfortunatelly, I can't take right results using atanh.
[quote=steeve88]This gives me back values between -3 and 3, but this is not angle values again.[/quote]
That will be -pi to pi.
Try scaling the result by 180/pi.
December 8, 2014 at 04:01 am - Permalink
This gives me values from 2 to -2. I use wind direction values, thus values from 0 to 360, so this is not a reasonable result.
December 8, 2014 at 04:41 am - Permalink
Can you provide more explanation of what you need here please?
December 8, 2014 at 05:56 am - Permalink
December 8, 2014 at 06:13 am - Permalink
December 8, 2014 at 06:28 am - Permalink
Perhaps someone else can help?
December 8, 2014 at 06:31 am - Permalink
December 8, 2014 at 09:07 am - Permalink
December 9, 2014 at 01:48 am - Permalink
December 9, 2014 at 02:04 am - Permalink
DisplayHelpTopic "atan"
DisplayHelpTopic "atan2"
this says e.g. for atan2 that the input is expected to be in radians and the output values range from -pi to +pi.
December 9, 2014 at 02:05 am - Permalink
I converted degrees to radians before the calculations, and finally I converted the result of arctan again into degrees.
December 9, 2014 at 04:06 am - Permalink
