I read (though I can't find it now) that make and duplicate do not create wave references when using the $. (see below for duplicate example). I don't really have a grasp of what this means, but wonder if it is the reason the below code works. I duplicate input, which has length 418, and set it to be the wave associated with the string ftemp (is this a reasonable way to think about this? it's how i phrase it in my head). I then set f to be the local wave variable, so that I can manipulate the wave associated with $ftemp. At this point, I would guess f should still have 418 length. But then I set the output of a Fourier transform to f. The output has length 204.
I'm wondering why this works.
Is it 1. Because the duplicate command didn't assign a wave reference? And what does that mean in this context? 2. The FFT will adjust the destination wave if neccesasry? 3. Something else?
function fbw(input, stepsize)
wave input
variable stepsize
string ftemp = nameofwave(input)+"_FFT"
duplicate/o input, $ftemp
wave f = $ftemp
FFT/OUT=3/DEST=f input
You should get: 210
The next curiosity is why you are bothering to create a wave for the destination? The whole idea for /DEST flag is to be used as above, i.e., you do not have to create the output before you execute the transform. If you specify a destination which already exists, it does not really matter how many points are in this wave. As long as you are not trying to pass a Text wave to /DEST, the wave is overwritten with the appropriate number of points for the transform. For a real wave input of N points, the transform is (1+N/2), which in this case is 1+209.
December 9, 2014 at 11:30 am - Permalink
December 9, 2014 at 12:22 pm - Permalink
December 9, 2014 at 12:24 pm - Permalink
Thank you, this answers my question. I just tried it with a complex transform, and it doesn't seem to matter if the destination was real...it becomes complex when the FFT command executes.
December 9, 2014 at 12:28 pm - Permalink
