Table access to Y dimension labels
I use dimension labels quite a lot. They are often filled programatically but when I do this manually I wish I could navigate through the Y dimension as easily as through the X dimension.
Is there any chance to get to those using the arrow keys instead of having to double click each label individually?
You do know that if you swap the rows and column in the table that you can just type in the (now) Y column and hit return to go to the next Y dimension label, right?
Use the little "circling arrows" popup to swap rows and columns in the table.
JimProuty wrote: You do know that if you swap the rows and column in the table that you can just type in the (now) Y column and hit return to go to the next Y dimension label, right?
No, I didn't! Yes, this is a work around for the few cases I fill labels manually.
I use this a lot now but in the case of 2D waves I don't see any benefit of having the "swapping rows and columns" dialogue popping up after pressing the "circling arrows" button.
My suggestion would be either to have an e.g. alt-click option to directly swap x and y dimension by default without doing this manually (even for 3D waves), or to get rid of the dialogue for 2D waves.
