Resampling data: less points for discrete time steps
I have (say) 1000 points (wave A) collected from 10:00:00 am up to 10:19:59 am (wave B). About 1 point per second, but not exactly.
How can I "resample" those data considering 20 (integer) minutes (wave D), having a single point per single minute (wave C)?
That is, 20 points, 20 minutes. Wave D (1-20 minutes) is trivial.
Wave C should be a sequence of 20 mean values of about 50 points per time (1000/20) from wave A, I guess.
Analysis > Resample, setting Interpolate/Decimate 20/1000, didn't work for me.
What can I do?
That will depend on the format of your data (x and y waves versus a waveform).
I suggest you attach your data waves or an entire Igor experiment containing your data and be more specific about what you want to do.
JimProuty wrote: That will depend on the format of your data (x and y waves versus a waveform).
My entire experiment is pretty huge, so I have to attach just a table with 2 waves: measured data, and time of measure (just as a reference).
I need to plot a new wave of (about) 120 points, from Wave A, with respect to another wave of 120 points (from a modelization). 120 comes from time steps adopted; I can change them in 240 (30 seconds) and so on.
Thank you in advance, Jim.
Greetings
Table9.pxp (100.31 KB)
I see; you have a time-of-measurement wave (Wave_B) that is usually simply one second after another, except that randomly there is a two-second interval instead.
And you have the measurement result in another wave (Wave_A) at only those times.
In addition, these waves contain about 7200 measurements where you want to represent the average using only, say, 120 measurements (one every 60 seconds).
The solution involves two steps:
1) convert your X/Y data into a waveform with the missing measurements replaced by interpolation.
2) resample (or decimate) the waveform by a factor of 60.
Here's the code I wrote to convert your data from XY to a gap-less waveform:
Macro FillGaps(measuredYWave, timesXWave, suffix)
	String measuredYWave
	String timesXWave
	String suffix= "_nogaps"
	Prompt measuredYWave, "Measurement (Y) wave", popup, WaveList("*",";","")
	Prompt timesXWave, "Time (X) wave", popup, WaveList("*",";","")
	Prompt suffix, "suffix for \"no gaps\" waves"
	String noGapsWaveform = FillWaveGaps($measuredYWave, $timesXWave, suffix)
	if( strlen(noGapsWaveform) )
		Edit $noGapsWaveform.id
		Display $noGapsWaveform
Function/S FillWaveGaps(yw, xw, suffix)
	Wave/Z yw, xw
	String suffix
	if( !WaveExists(yw) || !WaveExists(xw) )
		Print "both waves must exist!"
		return ""
	Variable suffixLen= strlen(suffix)
	if( (suffixLen < 2) || (suffixLen > 20) )
		Print "use a suffix between 2 and 20 characters (shorter is better)"
		return ""
	String noGapsWfmName = (NameOfWave(yw)+suffix)[0,30]
	// compute smallest increment of time
	Differentiate/METH=1 xw/D=tmp_x
	WaveStats/Q/M=0 tmp_x
	Variable minTimeInc = V_Min
	KillWaves/Z tmp_x
	// compute time range
	Variable time0 = xw[0]
	Variable timeLast = xw[numpnts(xw)-1]
	Variable numTimes = (timeLast-time0)/minTimeInc
	numTimes = ceil(numTimes)
	// Make waveform from XY
	Make/O/D/N=(numTimes) $noGapsWfmName/WAVE=noGaps
	SetScale/P x, time0, minTimeInc, "dat", noGaps
	noGaps = interp(x, xw, yw)	// linear interpolation
	return noGapsWfmName
The resulting Measured_nogaps waveform is then reduced by a factor of 60 using the Resample dialog:
•Duplicate/O Measured_nogaps,Measured_nogaps_samp
•Resample/DOWN=60/N=59/WINF=None Measured_nogaps_samp
Resulting experiment is attached. I have renamed Wave_A and Wave_B to Measured and TimeOfMeasurement for clarity.
BiorTable9.pxp (286.7 KB)
Thank you so much, Jim.
Needless to say, your macro works perfectly. I have still some issue in resampling waves with an arbitrary number of points, but I think that decimating the total number of points, and interpolating the number of points I want, should work. The filters too are not totally clear to me, but I can manage that.
Thank you again! Bye.
