Create plot with a specific color gradient background?
I am trying to create a plot with a color gradient background (see attached image). I have some data on X-Y, and I want to compare them to certain distribution as the background. However, for the background (currently the grey part in the image) I would like to apply a color gradient that is proportional to the probability density of a distribution (e.g. exponential distribution). Is there a straightforward way to do this? Thanks in advance.
Best,
William
p.s. currently I drew the grey background using two points and fill to zero options in Igor figure.
February 9, 2015 at 09:48 am - Permalink
[quote=johnweeks]Instead of two points, use N points (N is the number of points in your distribution wave) then use Color as f(z) to give it the desired color gradient. If you really want shades of gray, use the Grays color table.
February 9, 2015 at 01:31 pm - Permalink
1) Use my suggestion, but when you add the trace to the graph use
AppendToGraph/VERT gradientWave2) Make a suitable matrix wave and fill it with appropriate values from your distribution, and display that matrix as an image. Use the Grays color table.
Solution 2 will allow any arbitrary gradient.
February 10, 2015 at 09:32 am - Permalink
[quote=johnweeks]Two possibilities come to mind:
February 10, 2015 at 03:28 pm - Permalink
