Replacestring for a text wave
Is there an efficient way to replace string entries in a text wave. For instance: I have a text wave like the one below where I want to replace all the "PSI " entries with"Psi".
make /n=10 /t TxtWave
TxtWave[0,4]="Psi"
TxtWave[5,9]="PSI "
//In the form of replacestring
Replace4txtWave("PSI ",TxtWave,"Psi")
function Replace4txtWave(replaceThisStr, TxtWave, withThisStr)
	string replaceThisStr
	wave /t TxtWave
	string withThisStr
	variable i
	for(i=0;i<numpnts(TxtWave);i+=1)
		if(cmpstr(replaceThisStr,TxtWave[i])==0)
			TxtWave[i]=withThisStr
Some of my text waves are long and my Replace4txtWave function is slowing my code down quite a bit.
s.r.chinn
The following command works for your example. I haven't tested whether it executes faster, but it avoids your explicit loop.
TxtWave = SelectString( cmpstr(TxtWave[p],"PSI")==0, "Psi", TxtWave[p])
Note that you can't use the
 <expression> ? <TRUE> : <FALSE>
construction for strings.
jtigor
I haven't tested this but, as a first pass at improving the performance, you could try replacing the for loop with the following
TxtWave[] = cmpstr(replaceThisStr, TxtWave[p]==0) ? withThisStr : TxtWave[p]
thomas_braun
You should move the numpnts(txtWave) out of the loop, as this called on every loop iteration.
What are your typical text waves sizes and do you know the ratio between matching entries and non matching entries?
andyfaff
I would use
FindValue
in a
do-while
loop. Use the
V_Value
output of the
FindValue
operation to specify where to start searching again. This operation has the advantage of being case sensitive, etc.
andyfaff
With this version replaceThisStr does not have to be a whole wave element (although you can make it do that by changing the TXOP flag). It's efficient because FindValue does all the searching outside of a loop.
	wave /t TxtWave
	string withThisStr
	variable V_Value = 0
	do
		//Look at documentation for what TXOP does.
		FindValue/S=V_Value /Text=replaceThisStr/TXOP=1/z TxtWave
		if (V_Value == -1)
			break
		TxtWave[V_Value] = replacestring(replaceThisStr, TxtWave[V_Value], withThisStr)
	while(1)
MGHuber
Thanks a bunch; I appreciate everyone's suggestions! The text waves that I'm operating on are typically 200,000 + points which inherently makes everything slow. I timed every one of the suggested alternatives. However each one (including my original for..loop based Replace4txtWave() took the same amount of time (on a PC). I suspect that I will have to look into an alternative to having such a large text wave (I'm stuck with however several non-text waves of similar size).
HJDrescher
Maybe it is faster to recreate the text wave with the changed entries.
The "programmer notes" in
displayhelptopic "text waves"
indicate a bottle neck in the memory management for text waves (which is hard/expensive to avoid).
HJ
aclight
Here is some code I used to test the different approaches.
Function test(waveSize)
	Variable waveSize
	String targetString = "PSI"
	String replacementString = "Psi"
	Make/N=(waveSize)/T/FREE/O originalTextWave
	originalTextWave[0,(waveSize/2) - 1] = replacementString
	originalTextWave[(waveSize/2), *] = targetString
	Variable method
	For (method = 0; method < 4; method +=1)
		Duplicate/O/FREE originalTextWave, testTextWave
		Variable start = StopMSTimer(-2)
		Switch (method)
			case 0:		// Original method
				Replace4txtWave(targetString, testTextWave, replacementString)
				break;
			case 1:		// SelectString method
				Replace4txtWave1(targetString, testTextWave, replacementString)
				break;
			case 2:		// FindValue method
				Replace4txtWave2(targetString, testTextWave, replacementString)
				break;
			case 3:		// MultiThread text wave assignment method
#if IgorVersion() >= 7
				Replace4txtWave3(targetString, testTextWave, replacementString)
#else
				print "Method 3 requires Igor 7."
#endif
				break;
		EndSwitch
		printf "Execution took %g ms using method %d.\r", (StopMSTimer(-2) - start)/1e3, method
	EndFor
	wave /t TxtWave
	string withThisStr
	variable i
	Variable waveNumPnts = numpnts(TxtWave)
	for(i=0;i<waveNumPnts;i+=1)
function Replace4txtWave1(replaceThisStr, TxtWave, withThisStr)
	wave /t TxtWave
	string withThisStr
	TxtWave = SelectString( cmpstr(TxtWave[p],replaceThisStr)==0, TxtWave[p], withThisStr)
function Replace4txtWave2(replaceThisStr, TxtWave, withThisStr)
	wave /t TxtWave
	string withThisStr
	variable startPoint = 0
	do
		FindValue/S=(startPoint)/TEXT=replaceThisStr/TXOP=4 TxtWave
		if (V_value == -1)	// Value not found
			break
		TxtWave[V_value]=withThisStr
		startPoint = V_value + 1
	while (startPoint < waveNumPnts)
function Replace4txtWave3(replaceThisStr, TxtWave, withThisStr)
	wave /t TxtWave
	string withThisStr
	// MultiThread with a text wave requires Igor 7 built 21Feb2015 or later.
	MultiThread TxtWave = Replace4txtWave3_worker(TxtWave[p], replaceThisStr, withThisStr)
ThreadSafe Function/S Replace4txtWave3_worker(actualString, replaceThisStr, withThisStr)
	String actualString
	string withThisStr
	if(cmpstr(replaceThisStr,actualString)==0)
		return withThisStr
	return actualString		// No replacement necessary
#endif			// IgorVersion() >= 7
Here are the results:
Igor 6
test(200000) Execution took 341.875 ms using method 0. Execution took 383.267 ms using method 1. Execution took 330.678 ms using method 2. Method 3 requires Igor 7. Execution took 15.8403 ms using method 3.
Igor 7
test(200000) Execution took 108.052 ms using method 0. Execution took 220.391 ms using method 1. Execution took 328.766 ms using method 2. Execution took 88.5857 ms using method 3.
If any Igor 7 preview testers want to reproduce these results, you must use the latest build dated 21Feb2015 or later in order to use method 3.
For even larger waves, method 3 performs even better relative to the other methods.
One note--If you're using Igor 6, the following three lines take longer to execute than the rest of the code:
Igor 7 has an optimization for text waves that apparently makes the creation of the text wave much faster.
aclight
I came up with a few additional methods that could be used for this task, and one of them is substantially faster than the previous methods.
Here is the test code:
	Variable waveSize
	Variable method
	For (method = 0; method < 6; method +=1)
//		print "before:", testTextWave
		Switch (method)
				break;
				break;
				break;
#else
#endif
				break;
			case 4:		// Extract method
				Replace4txtWave4(targetString, testTextWave, replacementString)
				break;
			case 5:		// Extract method
				Replace4txtWave5(targetString, testTextWave, replacementString)
				break;
		EndSwitch
//		print "after:", testTextWave
	EndFor
	wave /t TxtWave
	string withThisStr
	variable i
	wave /t TxtWave
	string withThisStr
	wave /t TxtWave
	string withThisStr
	do
			break
	wave /t TxtWave
	string withThisStr
	String actualString
	string withThisStr
		return withThisStr
function Replace4txtWave4(replaceThisStr, TxtWave, withThisStr)
	wave /t TxtWave
	string withThisStr
	Extract/FREE/O/INDX/T TxtWave, ExtractedWave, (cmpstr(replaceThisStr,TxtWave[p])==0)
	variable i
	Variable numToReplace = numpnts(ExtractedWave)
	for(i=0;i<numToReplace;i+=1)
		TxtWave[ExtractedWave[i]]=withThisStr
function Replace4txtWave5(replaceThisStr, TxtWave, withThisStr)
	wave /t TxtWave
	string withThisStr
	Grep/INDX/Q/E="^" + replaceThisStr + "$" TxtWave
	WAVE W_Index
	variable i
	Variable numToReplace = numpnts(W_Index)
		TxtWave[W_Index[i]]=withThisStr
Here are results on my Windows machine (the previous test results were on my Macintosh machine):
Igor 6
•test(200000) Execution took 246.57 ms using method 0. Execution took 274.317 ms using method 1. Execution took 258.047 ms using method 2. Method 3 requires Igor 7. Execution took 0.846398 ms using method 3. Execution took 272.347 ms using method 4. Execution took 180.707 ms using method 5.
Igor 7
•test(200000) Execution took 104.597 ms using method 0. Execution took 87.317 ms using method 1. Execution took 219.459 ms using method 2. Execution took 47.842 ms using method 3. Execution took 125.289 ms using method 4. Execution took 166.079 ms using method 5.
thomas_braun
Thanks for sharing the code aclight.
In that special case here one can speed up the initial wave assignment with preallocated storage
	Make/N=(waveSize)/T=(strlen(targetString))/FREE/O originalTextWave
Nice to see IP7 perform so quickly with the new text wave memory layout mentioned in [1]. Looking at your code the new memory layout seems also to be the default in IP7.
I'd extend the grep code as follows
	Grep/INDX/Q/E="^\\Q" + replaceThisStr + "\\E$" TxtWave
so that any funny characters in replaceThisStr are taken literally.
[1]: http://wavemetrics.com/search/viewmlid.php?mid=27741
aclight
thomas_braun wrote: Thanks for sharing the code aclight.
Using Igor 6, using /T=size does decrease the time it takes to execute the Make statement that creates the originalTextWave wave, but it doesn't change the performance of the text replacement by more than a few ms one way or another.
Using Igor 7, the text wave is created quickly whether or not /T=size is used. However, if it's created using /T=size, the actual replacement methods execute slower. In particular, the Igor 7 only method 3, that uses a MultiThread wave assignment statement, is slower because the MultiThread keyword is ignored if the target of a text wave assignment stores the text data in contiguous bytes instead as an array of pointers. Using /T=size forces the wave's text data to be stored as contiguous bytes. So I don't recommend it's use in this situation unless the real-life bottleneck is in the initial creation of the wave and not in the replacement.
Here are the timings on Macintosh using Igor 7:
// Line 8 is: Make/N=(waveSize)/T/FREE/O originalTextWave •test(200000) Execution took 112.238 ms using method 0. Execution took 77.6911 ms using method 1. Execution took 344.949 ms using method 2. Execution took 72.5701 ms using method 3. Execution took 109.374 ms using method 4. Execution took 143.778 ms using method 5. // Line 8 is: Make/N=(waveSize)/T=(strlen(targetString))/FREE/O originalTextWave •test(200000) Execution took 197.69 ms using method 0. Execution took 168.698 ms using method 1. Execution took 443.477 ms using method 2. Execution took 287.046 ms using method 3. Execution took 205.962 ms using method 4. Execution took 181.9 ms using method 5.
Yes, that's a good idea when creating a regular expression from user input.
