Comparison between Matlab and Igor
I am calculating the second derivative of a particular data range regarding Raman spectra both with igor and matlab....I noticed that the amplitude is higher in Matlab with respect to igor.....it is also likely that the position of a peak revealed in the second derivative has 1 wavenumber difference between matlab and igor....this seems a bit strange to me since its the same data set. Any suggestions?
Thnaks,
Konstantinos
Konstantinos Chatzipanagis wrote: Hi,
Thnaks,
Konstantinos
Igor has 3 different kinds of differentiation algorithms. If you want agreement, choose the algorithm that Matlab also uses.
Thanks for that......However, how can i choose between algorithms? I am basically using the differentiate option given and just do it.....How is it possible to choose between algorithms?
Regards
i found out how to do it....however, using backward or forward differences solves the problem partly.....now the second derivatives seem a lot more similar but there is still a problem.....using matlab i get maximum negative values up to -3 in the second derivative, while with igor pro up to -2.....i am trying to understand why is that.
Note that the Differentiate operation, if you don't use the /X flag, takes the source wave's X scaling into account. For example:
Make jack=sin(x/8)
Differentiate jack /D=dif1
SetScale/P x, 0, .1, jack
Differentiate jack /D=dif2
Display dif1, dif2
For information on X scaling, execute:
