Contour plot with polar axis
Hi all,
I am looking for a way to plot a 2-D wave on a polar graph, which doesn't seem to be straight forward on Igor.
I have already gone through the 2 threads dealing with the subject (http://www.igorexchange.com/node/2606 & http://www.igorexchange.com/node/5469), but I must say I am fairly new to programming with Igor (usually use Python) and I can barely find/understand what works best in my case...
Ok, so, I have a 2-D wave, with angles as rows and wind speed as columns (or the other way around, just need to transpose the matrix if needed). Each cells contains concentration values.
How would you (in concrete terms) convert the "rectangle" image to a polar projection?
Many thanks for your help!!
J-E
Igor
J-E
Your description is somewhat lacking in detail. If I understand you correctly, you have a 2D wave where the rows correspond to some angles and the cols correspond to some speed and the actual cells represent some scalar values. I assume from this that you want to display the scalar values on a coordinate system where the "angles" correspond to say polar angles and the speed would correspond to the magnitude of the polar radius. If that is the case:
Function convertToPolar(inWave)
	Wave inWave
	Variable rows=dimsize(inWave,0)
	Variable cols=dimSize(inWave,1)
	Variable points=rows*cols
	Make/O/D/N=(points,3) polarTriplet
	Variable i,j,angle,count=0,rad
	// assuming angle is in radians measured CC from the positive x-axis:
	for(i=0;i<cols;i+=1)
		rad=dimOffset(inWave,1)+i*dimDelta(inWave,1)
		for(j=0;j<rows;j+=1)
			angle=dimOffset(inWave,0)+j*dimDelta(inWave,0)
			polarTriplet[count][0]=rad*cos(angle)
			polarTriplet[count][1]=rad*sin(angle)
			polarTriplet[count][2]=inWave[j][i]
			count+=1
When you have converted to polarTriplet simply display a contour of this triplet wave.
HTH,
J-E Petit
Hi all,
Thanks veru much for your answers!!! I tried both suggestions, but before, I'd like to be more thorough on the description of the data and the objective of my procedure :)
First, I enclose the polar plot I get from my Python script, which I would like to reproduce on Igor (file Polar plot Python). the polar angles are obviously associated with wind direction, and radius axis with wind speed. f(z) colors are linked to concentration values at each wind direction & speed.
Then, I enclose what I have in Igor (already reproduce the calculation to compute mx values). Image "Image_mx". My 2D wave, called "mx", is composed of 720 rows, describing angles from 0° to 359.5° with an angular resolution of 0.5°, and 40 columns representing wind speed from 0 to 20 km/h and a speed resolution of 0.5 km/h.
The idea is then to "tranform" the rectangular image plot to polar, just like the graph from Python.
I tried the convertToPolar function, but the result doesn't look like satisfactory. (image "Contour_plt_convertToPolar"). I used 100 levels, without labels.
I tried the DisplayPolarImage macro, and got a polar-like graph, which is a good news! But the data used doesn't look like correct. I executed "DisplayPolarImage("mx",2,angle_rad)"; where angle-rad is a 1D wave containing 720 rows describing the angles in radian.
Maybe I didn't use your functions correctly?
Thanks again for your help
J-E
Polar plot Python.png (341.11 KB) Image_mx.png (44.2 KB) Contour_plt_convertToPolar.png (78.55 KB) DisplayPolarImage.png (98.6 KB)
Igor
I am not sure exactly what you tried there. Remember, posting images is not nearly as useful as posting a small IGOR experiment with the relevant data.
Before you use convertToPolar() you need to make sure that your wave scaling is indeed in radians. I suspect it might be in degrees which could explain the strange result. After you change either the wave scaling or add the appropriate factor to the "angle" variable you should get a polarTriplet wave which you can now interpolate at any resolution you want. The pixelated image you show in one of your results indicates insufficient sampling. If you use ImageInterpolate (with the keyword Voronoi) directly, you have the freedom to adjust the parameters to the /S flag and determine the boundaries and sampling in both directions. Your command would look something like:
ImageInterpolate/S={xmin,dx,xmax,ymin,dy,ymax} voronoi polarTriplet
The results are stored in the wave M_InterpolatedImage in the current data folder.
HTH,
J-E Petit
wave scaling is a concept which I'm not fully confident with. But before bothering you, I'll go through the manual; I'll probably find all I need :)
J-E Petit
Hi!
I think I got my wave scaling right; but I realized that your function assumes anles (in rad) calculated counterclockwise from the positive x-axis. And the polar graph would need clockwise angles from the positive y axis (0° corresponds to the North). This would probably explain the weird countour plot that I get.
I guess the "most simple" way to overcome this is to modify the converttopolar() procedure; but I would be unable to do it myself...
Any hint?
If necessary, I can provide the 2D wave I'm using(?!)
Igor
J-E Petit wrote: Hi!
Any hint?
I'm not a big fan of wave scaling myself so it is fine by me if you don't use it. In that case you need to assume something about your sampling, and state it. Here is how I'd change the code:
	Wave inWave
	// assuming angle is in degrees measured clockwise from the y-axis
	Variable da=pi/360				// 2*pi/720
		rad=0.5*i					// wind speed in 0.5 km/hr increments
			angle=j*da				//
			polarTriplet[count][0]=rad*sin(angle)
			polarTriplet[count][1]=rad*cos(angle)
			count+=1
HTH,
AG
J-E Petit
The lines you provided helped me a lot to get a function that works smoothly (probably not optimized); thanks so much!!
In a similar way, I created 3 waves so that for each angle, there is 200 corresponding wind speed values; and for each (angle,speed) couple there is one concentration value. It is just a matter of wave redimensionning (code is below)
Function polar(inWave)
	wave inWave
	Make/O/D/N=(points) xpolar
	Make/O/D/N=(points) ypolar
	wave mx
	duplicate mx mxT
	MatrixTranspose mxT
	variable i,count=0,j=0
	wave angle, speed
	for (i=cols-1;i<points;i+=cols)
		xpolar[i-cols+1,i]=angle[count]
		count+=1
	for (i=0;i<rows;i+=1)
		Concatenate/O/NP {speed, ypolar}, temp
		ypolar=temp
	KillWaves temp
	duplicate mxT zpolar
	Redimension/E=1/N=(points) zpolar
End Function
Function plot()
	wave ypolar, xpolar, zpolar
	WMNewPolarGraph("", "")
	WMPolarAppendTrace("PolarGraph0",ypolar, xpolar,360)
	ModifyGraph mode=2,lsize(polarY0)=2,zColor(polarY0)={zpolar,*,*,Rainbow,1}
	SetDataFolder root:Packages:WMPolarGraphs:PolarGraph0:
	variable/G angleDirection
	variable/G zeroAngleWhere
	angleDirection=1
	zeroAngleWhere=90
End Function
Then, I have a nice surface plot on polar axes, but the axes are all below the trace (see enclosed image). I checked the "draw on Top of Graph" button for the Vert and HorizCrossing axes, but it didn't do anything. Is there an other way to overcome this?
polar surface plot.png (295.28 KB)
JimProuty
Any hint?
Please do; I think that using the Polar Graphing package for your data is not a good idea (the polar graphing macros don't provide for drawing the axes in front of the traces).
Creating an image plot and your own polar axes is more workable.
J-E Petit
Here is the mx enclosed
"mx" consists of 720 rows (corresponding to angles from 0 to 360 with a resolution of 0.5) and 200 columns (corresponding to wind speed from 0 to 20 km/h with a resolution of 0.1 km/h)
I also enclosed the "angle" and "speed" waves, just in case.
polar plot mx.pxp (1.12 MB)
JimProuty
I applied X scaling to mx's rows and Y scaling to columns (i used km/h aka kmph)
SetScale/P x 0,0.5,"deg", mx	// 0.5 degrees per row
SetScale/P y 0,0.1,"kmph", mx	// 100 meters per hour per column
Then I opened Polar Image.ipf (saved from http://www.igorexchange.com/node/6288) as a Procedure file, and then closed it (without killing it), which automatically compiles all procedures.
Then I chose DisplayPolarImage from the Macros menu, which displays first one dialog where you choose the matrix, choose degrees for angle units, and choose X scaling for Angle from.
Click Continue to get to the second dialog, use conservative numbers like 200x200 rows x columns for the rectangular polar image because this part is dog-slow. It took about an hour to complete the Voronoi interpolation.
If you chose Yes for Display matrix as image? then you see a grayscale image plot with reversed Y axis. Ignore this, we can do better.
There is another way to display the image by using the attached experiment which modifies the New Polar Graphs code by having these Override definitions in the main Procedure window (the Overrides cannot be moved elsewhere):
#include <New Polar Graphs>
// Overrides work from only the main Procedure window.
Override StrConstant sLayerGrid = "ProgFront"
Override StrConstant sLayerAxes = "ProgFront"
Override StrConstant sLayerAxisLabels = "UserFront"
Macro MakePolarGraphForImage(matrixName)
	String matrixName
	Prompt matrixName, "polar Image", popup, WaveList("*Image",";","DIMS:2")
	fMakePolarGraphForImage($matrixName)
Function fMakePolarGraphForImage(matrix)
	Wave matrix
	// create a polar pair that spans the matrix extent
	Variable dx= DimDelta(matrix,0)
	Variable xmin= DimOffset(matrix,0)
	Variable xmax= xmin + dx*(DimSize(matrix,0)-1)
	Variable dy= DimDelta(matrix,1)
	Variable ymin= DimOffset(matrix,1)
	Variable ymax= ymin + dy*(DimSize(matrix,1)-1)
	String matName= NameOfWave(matrix)
	String radiusname= CleanupName(matName[0,28]+"_r",1)
	String angleName= CleanupName(matName[0,28]+"_a",1)	// radians
	Make/O/D/N=0 $radiusname/WAVE=radius
	Make/O/D/N=0 $angleName/WAVE=radians
	Variable/C topLeft= r2polar(cmplx(xmin,ymin))
	Variable/C bottomRight= r2polar(cmplx(xmax,ymax))
	radius= {real(topLeft), real(bottomRight)}
	radians= {imag(topLeft), imag(bottomRight)}
	String graphName= UniqueName("PolarImage",6,0)
	graphName= WMNewPolarGraph("_default_", graphName)
	String traceName= WMPolarAppendTrace(graphName,radius, radians, 2*pi)
	ModifyGraph/W=$graphName lsize($traceName)=0
	AppendImage/W=$graphName/L=VertCrossing/B=HorizCrossing matrix
	ModifyImage/W=$graphName $NameOfWave(matrix) ctab= {*,*,Rainbow256,0}
	WMPolarAxesRedrawGraphNow(graphName)
	WMPolarGraphs(1)	// show the panel, switch to Range tab
	WMPolarSwitchTab(1)
Then call the MakePolarGraphForImage macro with mxImage to get polar axes on top of the polar image.
You can set the range in the Polar Graphs Range tab and the Angle Axes Thickness to mask the ragged edge a bit. See the resulting image and attached experiment.
polar plot mx_0.pxp (3.39 MB) polar plot mx_0.pxp (3.39 MB) PolarImage0.png (80.98 KB) polar plot mx_0.pxp (3.39 MB)
JimProuty
I've updated Polar Image.ipf at http://www.igorexchange.com/node/6288 to provide control of angle rotation direction and for where angle=0 is located.
That was motivated by changes I made to the MakePolarGraphForImage procedure which uses Polar Image.ipf.
This revision still requires you to set the resulting polar graph's angle rotation direction and angle=0 location to match the values given to DisplayPolarImage().
The revised procedures prompt the user for those parameters. Really the only change to this code is:
	Prompt matrixName, "polar Image", popup, WaveList("*Image*",";","DIMS:2")
For convenience, here is the entire revised Procedure code (this code MUST be in the main Procedure window):
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
#include
	String matrixName
	Wave matrix
	WMPolarSwitchTab(1)
J-E Petit
Hi Jim,
I took a little bit of time to get back to your procedure. It works nicely, and what is useful is that you can change the settings of the graph through the polargraph panel. However, the calculation of mxImage take way too much time...
So as I tried earlier in this post, I plotted as a surface plot my triplet wave on a polar graph. And as the axes were beneath the surface plot, I tried to manually draw them on the graph. I don't really know if it is the most suitable solution, because one needs to interact with the "axes" through the procedure.... but it's works pretty well and it's fast....
	wave inWave
	wave angle, speed
		count+=1
		ypolar=temp
	KillWaves temp
	duplicate inWave zpolar
	MatrixTranspose zpolar
End Function
Function plot(MxToPlot)
	wave MxToPlot
	polar(MxToPlot)
	Make/O/N=3600 edge_angle, edge_line0, edge_line1, edge_line2,edge_line3
	edge_angle=p*0.1
	edge_line0=Wavemax(ypolar)
	edge_line1=edge_line0/4
	edge_line2=edge_line1*2
	edge_line3=edge_line1*3
	Make/O/N=2 x_axis1, x_axis2, x_axis3, x_axis4, y_axis
	y_axis=Wavemax(ypolar)
	x_axis1=180*p
	x_axis2=x_axis1+45
	x_axis3=x_axis2+45
	x_axis4=x_axis3+45
	variable/G tickLabelBlue
	variable/G tickLabelGreen
	variable/G tickLabelRed
	variable/G radiusAxisColorBlue
	variable/G radiusAxisColorGreen
	variable/G radiusAxisColorRed
	variable/G angleAxisColorBlue
	variable/G angleAxisColorGreen
	variable/G angleAxisColorRed
	angleDirection=1
	zeroAngleWhere=90
	tickLabelBlue=65535
	tickLabelGreen=65535
	tickLabelRed=65535
	radiusAxisColorBlue=65535
	radiusAxisColorGreen=65535
	radiusAxisColorRed=65535
	angleAxisColorBlue=65535
	angleAxisColorGreen=65535
	angleAxisColorRed=65535
	SetDataFolder root:
	WMPolarAppendTrace("PolarGraph0",edge_line0, edge_angle,360)
	WMPolarAppendTrace("PolarGraph0",edge_line1, edge_angle,360)
	WMPolarAppendTrace("PolarGraph0",edge_line2, edge_angle,360)
	WMPolarAppendTrace("PolarGraph0",edge_line3, edge_angle,360)
	WMPolarAppendTrace("PolarGraph0",y_axis, x_axis1,360)
	WMPolarAppendTrace("PolarGraph0",y_axis, x_axis2,360)
	WMPolarAppendTrace("PolarGraph0",y_axis, x_axis3,360)
	WMPolarAppendTrace("PolarGraph0",y_axis, x_axis4,360)
	ModifyGraph width=566.929,height=566.929
	ModifyGraph mode=2,lsize(polarY0)=5,zColor(polarY0)={zpolar,*,*,SeaLandAndFire,0}
	ModifyGraph mode(polarY1)=0,lsize(polarY1)=3,rgb(polarY1)=(0,0,0)
	ModifyGraph lstyle(polarY2)=2,rgb(polarY2)=(65535,65535,65535),mode(polarY2)=0
	ModifyGraph lstyle(polarY3)=2,rgb(polarY3)=(65535,65535,65535),mode(polarY3)=0
	ModifyGraph lstyle(polarY4)=2,rgb(polarY4)=(65535,65535,65535),mode(polarY4)=0
	ModifyGraph lstyle(polarY5)=2,rgb(polarY5)=(65535,65535,65535),mode(polarY5)=0
	ModifyGraph lstyle(polarY6)=2,rgb(polarY6)=(65535,65535,65535),mode(polarY6)=0
	ModifyGraph lstyle(polarY7)=2,rgb(polarY7)=(65535,65535,65535),mode(polarY7)=0
	ModifyGraph lstyle(polarY8)=2,rgb(polarY8)=(65535,65535,65535),mode(polarY8)=0
	TextBox/C/B=1/F=0/A=MC/N=text0/X=0.18/Y=49.28 "\\Z18\\f01N"
	TextBox/C/B=1/F=0/A=MC/N=text1/X=36.27/Y=34.91 "\\Z18\\f01NE"
	TextBox/C/B=1/F=0/A=MC/N=text2/X=48.24/Y=0.46 "\\Z18\\f01E"
	TextBox/C/B=1/F=0/A=MC/N=text3/X=37.44/Y=-34.87 "\\Z18\\f01SE"
	TextBox/C/B=1/F=0/A=MC/N=text4/X=0.95/Y=-49.39 "\\Z18\\f01S"
	TextBox/C/B=1/F=0/A=MC/N=text5/X=-36.28/Y=-36.36 "\\Z18\\f01SW"
	TextBox/C/B=1/F=0/A=MC/N=text6/X=-47.49/Y=0.27 "\\Z18\\f01W"
	TextBox/C/B=1/F=0/A=MC/N=text7/X=-34.51/Y=37.27 "\\Z18\\f01NW"
	Make/O/N=3 radialLabel
	variable/G s_res
	radialLabel=(p+1)*(WaveMax(ypolar)+s_res)/4
	TextBox/C/N=text8/F=0/X=37.26/Y=47.88 num2str(radialLabel[0])
	TextBox/C/N=text9/F=0/X=25.58/Y=47.88 num2str(radialLabel[1])
	TextBox/C/N=text10/F=0/X=14.99/Y=47.88 num2str(radialLabel[2])
End Function
NWR manual axes.png (193.86 KB)
