Non-parametric Wind Regression - speed up calculations
J-E Petit
Wed, 03/11/2015 - 08:08 am
I am working on the adaptation of a Python script I made to an Igor procedure for Non-parametric Wind Regression. First, what is NWR? it is a smoothing algorithm to better visualize the coupling of wind data (direction and speed) and pollutant concentrations. I enclosed the formulas associated with the methodology. It is basically, for each (theta,mu) couple a weighted average of concentrations where weighing coefficients are determined with two Kernel functions.
Thus, we can imagine having:
- an angle wave (theta), from 0° to 360° with a resolution of 0.5°, which makes 720 rows
- a speed wave (mu), from 0 to 20km/h with a resolution of 0.1, which makes 200 rows
The final concentration matrix will be (720,200)
So far, the procedure I wrote works pretty well, but it does the calculation cell by cell. Which takes quite a lot of time....
The ideal case would be to calculate the final matrix by only one mathemical operation (matrix multiplication), but it applies dealing with 3D matrices that are too big to handle for my computer (the concentration, ws, wd waves contains 3501 rows, leading to a 720*200*3501-element matrix). An other solution is to fragment the calculation to reduce the size of the 3D matrices.
But still, I am not very familiar with Matrix operations on Igor, and would need any kind of help!
I know my question is a pretty big thing to answer... apologies for that.
I enclose an Igor experiment in which this is:
- the NWR procedure I wrote
- some data (ws, wd, conc waves)
The main function is NWR(sigma,h). The others are here for data preparation.
Many many thanks in advance!
J-E
Please post your procedure file (missing from your experiment) if you want help optimizing the code.
March 11, 2015 at 10:22 am - Permalink
here it is
March 12, 2015 at 01:11 am - Permalink
1. You need to avoid using angles in degrees. You are wasting computation time on conversion back and forth. Keep everything in radians and modify labels at the very end for the benefit of people who do not understand pi/2.
2. I do not know which data waves are important to you so I did not modify much of the code. It would be better if you wrote your code with waves as function arguments so your inputs are clear.
3. Your goal should be to convert the double loop at the end of the procedure to straight matrix operations. You should be able to do that if you create intermediate 2D waves for diff_speed and the like.
4. Replace wave assignments with MatrixOP wherever possible.
Here is a first iteration of going through your code.
Variable angle_res
Variable i
Variable numPoints=360/angle_res
Make/O/N=(numPoints)/D angle
for (i=1;i<numPoints;i+=1)
angle[i]=angle[i-1]+angle_res
EndFor
Make/O/N=(8)/D angle_ticklocator=0
for (i=1;i<(numpnts(angle_ticklocator));i+=1)
angle_ticklocator[i]=angle_ticklocator[i-1]+45
EndFor
angle_ticklocator=angle_ticklocator/angle_res
Make/O/T angle_ticklabel = {"N", "NE", "E", "SE", "S", "SW", "W", "NW"}
Function init_speed(max_speed,speed_res)
Variable max_speed,speed_res
Variable i
Variable numPoints=max_speed/speed_res
Make/N=(numPoints)/D speed
speed[i]=speed[i-1]+speed_res
EndFor
Function init_mx(angle,speed)
wave angle,speed
Make/N=(numpnts(angle),numpnts(speed))/D mx
mx=nan
//wave angle_ticklocator,angle_ticklabel
//Display;AppendImage mx
//ModifyGraph userticks(bottom)={angle_ticklocator,angle_ticklabel}
//ModifyImage mx ctab= {*,*,Rainbow,1}
//ModifyGraph axisEnab(bottom)={0,0.9}
//ColorScale/C/N=text0/F=0/A=MC ctab={0,100,Rainbow,1}
//ColorScale/C/N=text0/A=RC/X=-1.65/Y=2.84
constant kInvsqrt2Pi= 0.3989422804014326779399460599343
Function Kernel1(x)
variable x
return exp(-0.5*x*x)*kInvsqrt2Pi
End Function
Function Kernel2(x)
variable x
variable cx=0.75*(1-(x*x))
if (cx<0)
Else
return cx
EndIf
Function NWR_init()
wave ws, wd
duplicate ws diff_angle diff_speed angle_Kernel1 speed_Kernel2, Ktot
diff_angle=nan
diff_speed=nan
angle_Kernel1=nan
speed_Kernel2=nan
Ktot=nan
constant kPi180= 0.017453292519943295769236907
Function angle_vec_diff(a1,a2)
variable a1,a2
variable b1,b2
b1=a1*kPi180
b2=a2*kPi180
variable c
c=cos(b1)*cos(b2)+sin(b1)*sin(b2)
return acos(c)/kPi180
Function NWR(sigma,h)
variable sigma, h
wave ws, wd, angle, speed, conc, mx, diff_angle, diff_speed, angle_Kernel1, speed_Kernel2, Ktot
variable i,j
Variable numPointsAngle=numpnts(angle)
Variable numPointsSpeed=numpnts(speed)
for (i=0;i<numPointsAngle;i+=1)
diff_angle=angle_vec_diff(angle[i],wd)/sigma // no dependence on j so factor out of loop
angle_Kernel1=Kernel1(diff_angle) // no dependence on j so factor out of loop
for (j=0;j<numPointsSpeed;j+=1)
diff_speed=(speed[j]-ws)/h
speed_Kernel2=Kernel2(diff_speed)
Ktot=speed_Kernel2*angle_Kernel1
MatrixOP/O/FREE mp=(Ktot^t) x conc
mx[i][j]=mp[0][0]/sum(Ktot)
EndFor
EndFor
I hope this helps,
March 12, 2015 at 11:48 am - Permalink
As I'm starting programming on Igor, the procedure may be a little messy; but I promise, I'll keep improving!
1/ got it. I am on of these people that are not very confident with radians... :)
2/ the most important waves are the input data (ws, wd and conc), and the "angle" & "speed" waves. The other waves are intermediate for the calculation. the "mx" 2D wave is the final result.
3/ Yes, exactly, and this is the heart the problem. The first thing I could try is to remove the second loop, by doing the calculation angle-by-angle with all speed values at each time. It will lead to the handling of 2D waves which, I guess, is manageable. I'll definitly try that first. The second solution is to remove the 2 loops, but it leads to 3D-matrices that are too big... or am I missing something?
4/ I am not familiar with matrixOP and/or wave assignment... what do you mean by assign waves with MatrixOP?
Thanks again!
March 12, 2015 at 03:24 pm - Permalink
I did not see any reason for a 3D matrix but then I may have missed something. Can you tell me what is the ultimate goal here? Are you performing some kind of interpolation? Also, your kernel is zero outside a limited domain -- you may be able to save a lot of multiplications by applying it locally.
MatrixOP is a built-in operation that speeds up wave assignments. For example
March 12, 2015 at 03:48 pm - Permalink
yep, it is a sort of interpolation. The ultimate goal is to have, for any wind direction & speed, a concentration value. All this from discreet variables at the input. Does it make sense to you? I enclose an image that may be clearer than some words.
Would the Interpolate XOP be useful here?
March 12, 2015 at 04:35 pm - Permalink
If the image on the left displays "scatter" of points were data are sampled, I'd approach the problem differently.
March 12, 2015 at 05:01 pm - Permalink
March 13, 2015 at 12:06 am - Permalink
I assume you have 3 waves of data: radius, angle and some scalar data each containing N points.
1. Create a triplet wave:
2. Fill the third column with scalar data:
3. compute the x and y cols from radius and angle waves:
tripletWave[][1]=radiusWave[p]*sin(angleWave[p]*pi/180)
4. determine the maximum radius value:
5. create a regular grid of interpolated data:
6. display the result:
Note that M_InterpolatedImage will contain NaNs outside the convex domain of the data.
HTH,
March 13, 2015 at 09:47 am - Permalink
ImageInterpolate/S={-rmax,dr,rmax,-rmax,dr,rmax} voronoi tripletWave
see attached image
maybe I did something wrong... but it seems like the "dr" variable is not defined. Is it related?
March 13, 2015 at 10:42 am - Permalink
March 13, 2015 at 10:44 am - Permalink
This sets the resolution of the output and depends on your data.
March 13, 2015 at 12:41 pm - Permalink
Variable/G dr2=0.1*sin(0.5*pi/180)
and then:
ImageInterpolate/S={-rmax,dr1,rmax,-rmax,dr2,rmax} voronoi tripletWave
but I get the same error, which is not very logical to me, because the ImageInterpolate operation doesn't need a /N flag....
March 15, 2015 at 12:26 am - Permalink
imageinterpolate/s={0,(dr),10,0,1,10} voronoi scatterWave
March 15, 2015 at 06:39 pm - Permalink
Tunrs out that calculations are particularly long. Maybe I used dr values that not adapted.
Anyway, I got back to the initial approach, and tried to get rid of one loop (out of the two). It seems to work pretty well, and it is way faster than calculations through each cell (now it is row-by-row). Maybe some lines of code can be optimized?
Next step is to plot the mx wave on a polar plot :) (already in progress on the forum)
Function init_angle(angle_res)
Variable angle_res
Variable i
Make/N=(360/angle_res)/D angle
for (i=1;i<(numpnts(angle));i+=1)
EndFor
Make/N=(8)/D angle_ticklocator
EndFor
End Function
Variable i
Make/N=(max_speed/speed_res)/D speed
for (i=1;i<(numpnts(speed));i+=1)
EndFor
End Function
wave angle,speed
Make/N=(numpnts(angle),numpnts(speed))/D mx, mx_jp
mx=nan
mx_jp=nan
Display/N=NWR_graph as "Wind apportioned concentrations";AppendImage mx
ModifyGraph/W=NWR_graph userticks(bottom)={angle_ticklocator,angle_ticklabel}
ModifyImage/W=NWR_graph mx ctab= {*,*,Rainbow,1}
ModifyGraph/W=NWR_graph axisEnab(bottom)={0,0.9}
ModifyGraph/W=NWR_graph fStyle(bottom)=1,fSize(bottom)=14,fStyle(left)=1,fSize(left)=14
ColorScale/W=NWR_graph/C/N=cb_NWR/F=0/A=RC/X=-9.61/Y=0.51 heightPct=110,image=mx,fsize=14
ColorScale/W=NWR_graph/C/N=cb_NWR "concentration"
SetScale/P y 0,0.5,"Wind speed (km/h)", mx
Display/N=JP_graph as "Joint probability";AppendImage mx_jp
ModifyGraph/W=JP_graph userticks(bottom)={angle_ticklocator,angle_ticklabel}
ModifyImage/W=JP_graph mx_jp ctab= {*,*,Rainbow,1}
ModifyGraph/W=JP_graph axisEnab(bottom)={0,0.9}
ModifyGraph/W=JP_graph fStyle(bottom)=1,fSize(bottom)=14,fStyle(left)=1,fSize(left)=14
SetScale/P y 0,0.5,"Wind speed (km/h)", mx_jp
End Function
Function Kernel1(x)
variable x
End Function
Function Kernel2(x)
variable x
if (cx<0)
Else
return cx
EndIf
Function NWR_init()
wave ws, wd
diff_angle=nan
diff_speed=nan
angle_Kernel1=nan
speed_Kernel2=nan
Ktot=nan
End Function
variable a1,a2
variable b1,b2
b1=a1*kPi180
b2=a2*kPi180
variable c
End Function
Function meshspeed(x)
variable x
wave speed, ws
Make/N=(numpnts(ws),numpnts(speed)) meshspeed_mx
variable i
for(i=0;i<numpnts(speed);i+=1)
meshspeed_mx[][i]=Kernel2((speed[i]-ws[p])/x)
duplicate meshspeed_mx,Ktot1
End Function
Function NWR3(angle_res,speed_max,speed_res,sigma,h,conc)
variable angle_res,speed_max,speed_res,sigma, h
wave conc
wave ws, wd
init_speed(speed_max,speed_res)
wave angle, speed
wave mx, mx_jp
NWR_init()
wave diff_angle, diff_speed, angle_Kernel1, speed_Kernel2, Ktot
meshspeed(h)
wave Ktot1,meshspeed_mx
variable i
Variable kNsigh=numpnts(conc)*sigma*h
Make/N=(1,numPointsSpeed)/D temp
Ktot1[][]=meshspeed_mx[p][q]
Ktot1[][]*=angle_Kernel1[p]
MatrixOP/O mp=(Ktot1^t) x conc
MatrixOP/O colSums = SumCols(Ktot1)
MatrixTranspose mp
temp=(mp[0][q])/colSums[0][q]
mx[i][]=temp[0][q]
mx_jp[i][]=colSums[0][q]/kNsigh
EndFor
March 17, 2015 at 09:49 am - Permalink
There are two components for that calculation: triangulation and interpolation. The value of (dr) will only affect the interpolation stage and its time-dependence is linear for each dimension. The triangulation is O(N^2) where N is the number of rows in your triplet wave.
Looking at the last function in your code, here are a few more suggestions you might want to try:
wave conc
wave ws, wd
wave angle, speed
wave mx, mx_jp
NWR_init()
meshspeed(h)
variable i
// convert to radians only once!
MatrixOP/O wds=wd*kPi180
MatrixOP/O angles=angle*kPi180
// create a single variable that eliminates one multiplication.
Variable invSigma=1/(sigma*kPi180)
Variable angles_i
// Duplicate is more efficient though in IP7 (see comment below)
// this instruction could be skipped completely.
// Ktot1[][]=meshspeed_mx[p][q]
Duplicate/O meshspeed_mx,Ktot1
// create a variable to pass MatrixOP.
angles_i=angles[i]
// eliminate function call:
// diff_angle=angle_vec_diff(angles[i],wds)/sigma
MatrixOP/O diff_angle=invSigma*acos(cos(angles_i)*cos(wds)+sin(angles_i)*sin(wds))
// angle_Kernel1=Kernel1(diff_angle)
MatrixOP/O angle_Kernel1=exp(-0.5*diff_angle*diff_angle)*kInvsqrt2Pi
Ktot1[][]*=angle_Kernel1[p] // In IP7 this would be MatrixOP/o Ktot1=scaleRows(Ktot1,angle_Kernel1)
MatrixOP/O mp=((Ktot1^t) x conc)^t
// MatrixTranspose mp
mx[i][]=temp[0][q]
EndFor
March 17, 2015 at 10:34 am - Permalink
