Cannot use MatrixOp replace
However, what rings alert is that the command "MatrixOp newwave = replace (timesort, 0.03, 2700)" did nothing on the wave, but if I manually erase the original data point and type in 0.03 in the cell, the matrixop would work, but only on those points that I have just manually typed in.
Is there anything that gets funky of my wave? I tried "browse wave", it looks similar to the other waves.
Thanks to whomever that offers help!
You can see this by showing the wave in a table. Right click on the wave in the table, choose digits, and choose 16. Notice that what had previously displayed as "0.03" now displays as "0.02999999999997272".
Alternately, you cold use
print/Dto display a value from the wave:April 6, 2015 at 06:13 am - Permalink
print/Dto display a value from the wave:Ah, no wonder I cannot do the thing I want, this is the reason why. Thank you aclight!! What makes me puzzled is why it has to be >= 13 digits to be able to see the difference? It looks deceptive if not going that high in digits. How does Igor display the values stored in a wave? Also what would be a good way to truncate a number to keep only the decimal part and round to only 2 or 3 decimal places?
Thank you!
April 6, 2015 at 09:53 am - Permalink
To round your data, you could use:
Substitute different values for 1000 to change the precision of the rounding.
April 6, 2015 at 12:42 pm - Permalink
Substitute different values for 1000 to change the precision of the rounding.[/quote]
Thank you aclight! I think you are right in that I might be a victim in the floating point error. The funky data is after I use
on the Timesort wave. What I am trying to do is chop the integer and only keep the digits after the decimal point in the new wave that is attached (this wave_decimal_day looks to be a normal wave).
I also tried
which gave me the same problematic wave.
Assuming the wave with the floating point error is wave_pro,
I can use
as you have suggested to round to only two decimal points,
or
It seems both can do the job, then my question would be if there is an advantage using one over the other? Or they are essentially doing the same thing?
I came up with
to round, but it is extremely slow compared to if a new wave is created,
Is there a glitch if I treat the wave_pro using the two chop function? And what would be the reason for the slowness?
What I ultimately want to do with the wave_decimal_day is to replace all the points ending in the same decimal parts with a same data entry in time, so I tried
and then loop through each point in the wave that has already been truncated to the two decimal points, but I can never get it right. What is it that I did wrong?
This ends up to be a bit too long, but thank you again in advance and indeed!
April 7, 2015 at 11:38 am - Permalink
I also tried
I can use
or
I came up with
[/quote]
I'm not sure what you're asking.
Your two chop functions execute in about the same amount of time on my machine (a few ms difference).
In general, MatrixOp is much faster than a wave assignment statement which is much faster than a loop (such as your chop functions). There are exceptions to the rule depending on what exactly you are doing.
[quote=mwpro]
What I ultimately want to do with the wave_decimal_day is to replace all the points ending in the same decimal parts with a same data entry in time, so I tried....
[/quote]
This might be what you're looking for:
April 7, 2015 at 02:23 pm - Permalink
I also tried
I can use
or
I came up with
[/quote]
[quote=mwpro]
[/quote]
That is an easy solve, thank you aclight! I was wondering if there is a procedure that functions like a pivot table in Igor? Thanks!
April 8, 2015 at 01:40 pm - Permalink
