Igor crashes saving wave as .itx (Igor Text Format)
I've attached an experiment with a problem I am having.
Namely, I want to save out a 1D wave in Igor Text format. I can save it out in tab-delimited format fine, but when I try to save the same wave in Igor Text format, it *does* save out, but Igor crashes immediately after saving the file.
If you Run "Main()" in the command line, you will see an example: the wave is saved as tab delimited, there is a pause, then Igor saves out the wave and crashes.
I've also attached the (long) operating system error report. For what it is work, I am running OS X 10.9
Any advice would be helpful!
WaveCopy.pxp (116.89 KB) ErrorMessage.pdf (86.55 KB)
johnweeks
Your experiment file lacks the procedure. Hold down the shift key and, while holding the shift key, select File->Adopt All. In the ensuing dialog, make sure everything is turned on except WaveMetrics Procedures. Save the result to a new file and post it.
By the way, this much of your crash report is relevant:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.wavemetrics.igorpromach 0x00423929 Slash + 73
1 ??? 0x72616573 0 + 1918985587
and it shows that Igor was well and truly trashed!
hrodstein
Based on the crash dump, you are running Igor Pro 6.35A5.
I get the crash in 6.35A5 but not in 6.37. So I think you just need to update. Choose Help->Updates for Igor.
