Update a graph using a slider
I am trying to update a graph by choosing the initial and final indices of the data wave using sliders.
I have something like this:
Window graph() : Graph
	Variable start,stop
	start = 0
	stop =  DimSize(pos,0)
	display vel[start,stop] vs pos[start,stop]
	ControlBar 42
	Slider slider0 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0}
EndMacro
Function SliderProc(ctrlName,sliderValue,event) : SliderControl
	String ctrlName
	Variable sliderValue
	Variable event	// bit field: bit 0: value set, 1: mouse down, 2: mouse up, 3: mouse moved
	if(event %& 0x1)	// bit 0, value set
How do I proceed to make the graph update based on the values of start, stop?
Thanks
HJDrescher
I typically would use a fixed display wave, e.g."root:DisplayData", which is redefined in the control procedure, e.g., by
duplicate /O /R(Start,Stop) datawave root:displaywave
within your if clause.
(Usually I have a fixed frame size and only use an assignment, but with dynamic ranges overwriting might be better than redefining)
Other opinions?
HJ
johnweeks
You can use ReplaceWave to replace trace with another that is different only in the subrange. Try it first using the Replace Wave item from the Graph menu to see what the command looks like.
JimProuty
You may be doing unnecessary work if Igor's Graph->Packages->Axis Slider is sufficient.
If not, you can look at that code to see how a slider can change a graph's axis range.
Function WMAxisSliderProc(name, value, event)
	String name	// name of this slider control
	Variable value	// value of slider
	Variable event	// bit field: bit 0: value set; 1: mouse down, //   2: mouse up, 3: mouse moved
	String dfSav= GetDataFolder(1)
	String grfName= WinName(0, 1)
	SetDataFolder root:Packages:WMAxisSlider:$(grfName)
	NVAR gLeftLim,gRightLim
	SVAR gAxisName
	GetAxis/Q $gAxisName
	Variable dx= (V_max-V_min)/2
	Variable x0= value*(gRightLim-gLeftLim)+gLeftLim
	SetAxis $gAxisName,x0-dx,x0+dx
	SetDataFolder dfSav
	return 0	// other return values reserved
igornoob12
JimProuty wrote: You may be doing unnecessary work if Igor's Graph->Packages->Axis Slider is sufficient.
	SVAR gAxisName
	SetDataFolder dfSav
Unless I misunderstood your solution I don't want to change the axis range but the number of wave data points that are displayed.
igornoob12
johnweeks wrote: You can use ReplaceWave to replace trace with another that is different only in the subrange. Try it first using the Replace Wave item from the Graph menu to see what the command looks like.
Thank you for the suggestion.
Here is what I got:
Window phase_space_graph() : Graph
	Variable/G start,stop
	start = 0
	display vel vs pos
	ControlBar 42
	Slider slider0 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0},size={300,63},ticks=0, variable=stop
	Slider slider1 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0},size={300,63},ticks=0, variable=start
EndMacro
	String ctrlName
	wave pos,vel
	NVAR start,stop
	if (CmpStr(ctrlName,"slider0"))
		stop = sliderValue
	elseif (CmpStr(ctrlName, "slider1"))
		start = sliderValue
		ReplaceWave trace= vel, vel[start,stop];DelayUpdate
		ReplaceWave/X trace= vel, pos[start,stop]
However, both sliders become coupled for some reason. i.e changing one also changes the other at the same time.
EDIT:
Nevermind, I figured it out. CmpStr returns "False" if the strings are equal.
JimProuty
igornoob12 wrote:
EDIT:
Technically, CmpStr returns 0 (not "false") if the strings are equal.
It also returns -1 if the first string is lexically "less than" the second, and it returns +1 if greater.
chozo
StringMatch
has the expected behavior in the above code. The matching criteria is a bit loose, as case sensitivity and such is not included. But by using wildcards one can also write case switches for groups of controls.
