Acquisition procedure
Hi, i've wrote this procedure, but I don't understand what is wrong!!! please help me!
function master(experimenttime, recordingtime, duration, rate, savedrate, plotresolution,savepath)
	variable experimenttime, recordingtime, duration, rate, savedrate, plotresolution
	string savepath
	variable psdflag=1 // first time, make the periodogram
	NewPath/O Path1,savepath//defines where to save the file
        // rate= sampling rate for data acquiring, like 40000 Hz
	// savedrate= rate for high time-resolution data recording, like 200 Hz
	// plotresolution= interval between each point on strip graph
	// recordingtime= interval for saving on disk, like 10s or 30s
	// experimenttime= global experiment time, after which acquisition stops, like 3600 s (break stops before and saves)
	string timenow=date()+" "+time() // date and time now
	string filename
	variable t0 = stopMSTimer(-2)/10^6 // consults the microseconds timer, from the moment of PC startup
	variable t1=0, dt1=0, dt2=0 // time init
	if (plotresolutionduration
	make /O/N=0 variancestrip //where to store the variance every plotresolution>duration
	setscale/P x, t1, (plotresolution), "s", timestrip, deflstrip, variancestrip
	setscale/P y, 0,1,"V" deflstrip, variancestrip
	setscale/P y,0,1,"s",timestrip
	//display
	display/W=(1,1,800,150) deflstrip vs timestrip
	AppendToGraph/L=L2 variancestrip vs timestrip
	ModifyGraph axisEnab(left)={0,0.45}
	ModifyGraph axisEnab(L2)={0.55,1}
	ModifyGraph freePos(L2)=0
	ModifyGraph lblPosMode(L2)=2
	ModifyGraph rgb(deflstrip)=(0,0,0)
	make /O/N=0 storeaverage, storevariance, storetime, waveaverage, wavevariance, wavetime
	display/W=(8, 310, 400,550) storeaverage vs storetime
	variable acq_cycle=0 // counter for acquisition cycle
	do //big loop for acquisition and plot
	   t1=stopMSTimer(-2)/10^6-t0 // evaluate the experimental time
	   //print "t1=",t1
	   waveacquire(t1, duration, rate, savedrate, psdflag) // DATA ACQUISITION
	    dt1+=stopMSTimer(-2)/10^6-t0-t1 // increment the delta time for plotting
	   dt2+=stopMSTimer(-2)/10^6-t0-t1 // increment the delta time for saving
	   insertpoints numpnts(storeaverage), numpnts(waveaverage), storeaverage // extends storeaverage
	   storeaverage[numpnts(storeaverage)-numpnts(waveaverage),
	       &&linewrap numpnts(storeaverage)-1]=waveaverage[p-numpnts(storeaverage)+numpnts(waveaverage)-1]
	   insertpoints numpnts(storevariance), numpnts(wavevariance), storevariance // extends storevariance
	   storevariance[numpnts(storevariance)-numpnts(wavevariance),
	       &&linewrap numpnts(storevariance)-1]=wavevariance[p-numpnts(storeaverage)+numpnts(waveaverage)-1]
	   insertpoints numpnts(storetime), numpnts(wavetime), storetime // extends storetime
	   storetime[numpnts(storetime)-numpnts(wavetime),
	       &&linewrap numpnts(storetime)-1]=wavetime[p-numpnts(storeaverage)+numpnts(waveaverage)-1]
	   acq_cycle=+1 //increment the counter for acquisition cycle
	   if (psdflag==1)
	     psdflag=0
	   endif // switches off psd
	   //print dt1," ",dt2
	   if (dt1>=plotresolution) // after exiting this loops, it adds a plot point ...
	     // insertpoints numpnts(deflstrip), 1, deflstrip, variancestrip // makes room
	     timestrip[numpnts(timestrip)]={stopMSTimer(-2)/10^6-t0} // to store the time too
	     deflstrip[numpnts(deflstrip)]={mean(storeaverage, pnt2x(storeaverage,
	       &&linewrap numpnts(storeaverage)-acq_cycle*rate/savedrate), pnt2x(storeaverage, numpnts(storeaverage)))}
	     variancestrip[numpnts(variancestrip)]={mean(storevariance, pnt2x(storevariance,
	       &&linewrap numpnts(storevariance)-acq_cycle*rate/savedrate), pnt2x(storevariance,
	       &&linewrap numpnts(storevariance)))/sqrt(acq_cycle*rate/savedrate)}
	     doupdate // explicitly ask to update the plots (in hope it has not done it before at insertpoint)
	    // print "plotplot"
	     dt1=0 //resets delta time for plotting
	     acq_cycle=0 // resets acquisition cycle, so it later knows what to use for plotting
	   if  (dt2>=recordingtime)
	     // saves storeaverage and storevariance on file with automatic names
	     // empty storeaverage and storevariance for next acquisitions
	     timenow=date()+" "+time() // updates time
	     filename="DeflectionStrip "+num2str(savedrate)+"Hz on "+timenow+"-"+num2istr(dt2)+".txt"
	     save /G/P=Path1 storetime storeaverage storevariance as filename
	     redimension/N=0 storetime, storeaverage, storevariance //clean up
	     dt2=0 //resets delta time for recording
	     psdflag=1
        while (t18192*4)
			segmentsize=8192// segment size for Periodogram calculation
			segmentsize=(duration*rate)/5
	//print segmentsize
	make/O/N=(rate*duration) wave0
	make/O/N=(rate*duration/blocksize) wavevariance // wave variance decimated
	make/O/N=(rate*duration/blocksize) waveaverage // wave after decimation
	make/O/N=(rate*duration/blocksize) wavetime // to store the time points
	make/O/N=0 media //to store the recordings
	make/O/N=0 timepoints //to store the time of recordings
	make/O/N=(segmentsize/2+1) periodogramdomain
	// variable timezero=(stopMSTimer(-2)-t0)/10^6 // resets the time
	//print timezero
	setscale/P x, t1, (1/rate), "s", wave0 // sets the spacing of the wave, so the sampling rate
	// next is commented so this is a SIMULATION for acquisition
	DAQmx_scan/DEV="dev4" WAVES="wave0, 2;" //acquires from DEV device on channel 2 and puts in wave0
	// must create a rate*duration size wave0
	// for adding a frequency, use sin(freq*x*2*Pi) x is already scaled in 1/rate seconds
	// variable phase=Pi*gnoise(1) // to start the noise at different phases
	// wave0=gnoise(1)+10*sin(3000*x*2*Pi)+sin(0.1*x*2*Pi+phase)// 3000 Hz vibration+ 0.1Hz vibration + gaussian noise
	// sleep/S duration // pause to simulate acquisition and do not mess the timings
	if (psdflag==1)
			DSPPeriodogram/Q/DLSG/NOR=(segmentsize*segmentsize/2)/SEGN={(segmentsize),(segmentsize/2)}/Win=hanning wave0
			filename="PSD "+num2str(savedrate)+"Hz on "+timenow+".txt" // for saving
			periodogramdomain=pnt2x(W_periodogram, p)
			save /G/P=Path1 periodogramdomain W_periodogram as filename
	wavevariance=variance(wave0, pnt2x(wave0, blocksize*p), pnt2x(wave0, (blocksize*(p+1))-1))/blocksize
	setscale/P x, t1, blocksize*(1/rate), "s", wavevariance // sets the spacing of the wave, so the sampling rate
	waveaverage=sum(wave0, pnt2x(wave0, blocksize*p), pnt2x(wave0, (blocksize*(p+1))-1))/blocksize
	setscale/P x, t1, blocksize*(1/rate), "s", waveaverage // sets the spacing of the wave, so the sampling rate
	wavetime=pnt2x(wavevariance, p) // timings from the scale (?)
	variable stoptimer=stopMSTimer(-2) // stops the microseconds timer
johnweeks
You're not giving us much to go on. Does it fail to compile? If so, what is the error message, and the line pointed to by the compiler?
Does it fail at run-time? If so, is there an error message? You should tell us what it is. A screen shot of an error alert is fine way to do that.
Maybe there is no message, but it doesn't do what you expect. If so, you should tell us what you expect and what it actually does.
That's a lot of code to look at if we have no guidance as to what is intended, and what goes wrong.
austenld
I don't know John, with out even an explanation of the problem, I can see at least one glaring concern. There are several unfilled lines; these extra lines contribute to a readability issue which OP is clearly referencing. If you want me to delete these extra lines, let me know OP and I'll update this post and make the necessary fixes.
Carlo
austenld wrote: I don't know John, with out even an explanation of the problem, I can see at least one glaring concern. There are several unfilled lines; these extra lines contribute to a readability issue which OP is clearly referencing. If you want me to delete these extra lines, let me know OP and I'll update this post and make the necessary fixes.
what kind of unfilled line?
Carlo
I'm sorry, John, but I had focused on the edit text igor and I forgot to continue the post.
So, the problem is not due to an error that is to compile, because everything is working without error.
The problem is due to the fact that I may have made some mistakes in the PSD.
(I state that I am making acquisitions with national card and an AFM.)
sw creates a series of waves, of which the major that I need are deflection vs. time and variance vs time.
The curve deflection vs. time does not present problems, for the variance vs time curve instead, there are problems.
I expect that the curve should be very steady, without peaks or drift I assure you that is not due to electronic noise as the AFM is isolated and placed in a Faraday cage.
HJDrescher
Some illustrative sample data would be very helpful.
In the mean time: Are all cables and connectors OK? Does the "artifact" arise from cross talk between the channels?
HJ
Carlo
This is an example of an acquisition:
experiment time: 3600s
duration: 30s
recording time: 30 seconds
saved rate: 200 Hz
plot resolution: 2
rate: 10000 hz
- Red = deflection vs. time (the correct curve because there is a thermal drift of the tip, and it is normal that it is negative)
- In blue = variance vs time that should not be so
all cables and connectors are OK, and I'm also acquiring from only one channel
HJDrescher
What is wrong with it?
Your signal is in the order of 1e0 = 1.
Your variance is around 10e-9 and 8 orders of magnitude smaller. (I would consider this as smooth.)
Maybe you want similar axis ranges for both traces for checking
SetAxis left 0,1
SetAxis right 0,1
HJ
Carlo
so do you think there's nothing wrong?
So why you see all those peaks? especially at different heights, and also there is a certain periodicity .....
However now I try, where should I put the "set axisis"?
here the first "display"?
display / W = (1,1,800,150) deflstrip vs Timestrip
AppendToGraph / L = L2 variancestrip vs Timestrip
ModifyGraph axisEnab (left) 0,0.45 = {}
ModifyGraph axisEnab (L2) = {0.55,1}
ModifyGraph FreePOS (L2) = 0
ModifyGraph lblPosMode (L2) = 2
ModifyGraph rgb (deflstrip) = (0,0,0)
////////NEW/////
SetAxis left 0,1
SetAxis right 0,1
HJDrescher
Why are you using a second left axis and put it on the right?
As the manual says, you can also use the /R flag to use the right axis...
AppendToGraph /R variancestrip vs Timestrip
I don't know your experiment and you are generally not providing much information. All I can tell you is that your variance is 8 orders of magnitude smaller than your signal. If you expect it to be 6 orders of magnitude smaller I would say this is good. If you expect it to be 20 orders smaller I would say it's very bad. (Just random numbers for illustration!)
The right axis range should not be smaller than your expected variance. Maybe add some waves to the graph indicating this limit. Otherwise the autoscale feature might make you think that there are peaks but in fact it's just low level noise.
HJ
Carlo
Of Course, the waves are saved as a file text named ExperimentStrip[...]
So I load the file wiht:
loadwave/g
display deflection(deflstrip) vs time(timestrip)
appendtogrpah/r variance(variancestrip) vs time(timestrip)
