Complex Wave used in real expression
When running the following function I always get a "Complex Wave used in real expression". The debugger shows that this happens in one of the if statements.
What is the problem?
Function getOmegaRsqr(rootWave,outputwave)
	Wave/C rootWave
	Wave outputwave
	NVAR alpha,betaa,bigOmega, omega0sqr
	Variable c1,c2,force
	variable j = 0
	for(j=0;j<dimSize(rootWave,0);j+=1)
		force = pnt2x(rootWave,j)
		c1 = (alpha*force^2)/(2*bigOmega^2)
		c2 = omega0sqr + (3*betaa*force^2)/(2*bigOmega^2)
		make/o/d/n=2 rootsTEMP
		variable count =0
		variable i=0
		for(i=0;i<3;i+=1)
			if((abs(imag(rootWave[j][i])/sqrt(magsqr(rootWave[j][i]))))<0.00000001)     //"Complex Wave used in real expression"
				if(c2+2*alpha*rootWave[j][i] + 3*betaa*(rootWave[j][i])^2 > 0)         //or possibly here
					rootsTEMP[count]=real(rootWave[j][i])
					count+=1
			elseif((abs(sqrt(magsqr(rootWave[j][i]))))<0.0000000000000001)              //"Complex Wave used in real expression"
					count+=1
		Endfor
		Variable root
		if(count == 0)
			print force
		if(count ==1)
			root = rootsTEMP[0]
		elseif(count == 2)
			//print rootsTEMP
			if(alpha>0)
				root = wavemax(rootsTEMP)
				root = wavemin(rootsTEMP)
		//print root
		outputwave[j] = c2 + 2*alpha*root+ 3*betaa*root^2
	Endfor
	killwaves rootsTEMP
Must be these constructs:
since the "if" commands expects a real value and the compiler is told ("/C") that rootwave is complex.
There is some "magsqr", "real", "imag", etc missing (like you used them in the line just above :-) )
HJ
HJDrescher wrote: Must be these constructs:
HJ
You are right, thanks. The first "if" checks if the number is real so I assumed that the value is "real".
