How to fix the error when use procedure
When I open a procedure, there appear a error warning named "#include "sp2_auto_utilities2.6"". Then I load the sp2_auto_utilities2.6 produce, why there still appear the same error warning?
Thanks a lot
Do you have a file called "sp2_auto_utilities2.6.ipf" in your User Procedures folder? Select Help->Show Igor Pro User Files. That will make an Explorer window showing the contents of your Igor User Files folder. There will be a folder there called "User Procedures". You need to put sp2_auto_utilities2.6.ipf into that folder.
Please read the help about this topic- copy this command, paste it into Igor's command line and press Enter:
DisplayHelpTopic "Special Folders"
