very disturbing behavior in compiler
Hi I am observing something that I don't think should happen.
Please see my attached file, and try compiling it on your machine.
Yes, there should be an error in the second call to 'Duplicate'.
However, no error is generated. I have observed this on two different computers.
Does anyone else see this error?
Jeff
Compiler_error.ipf (317 bytes)
JimProuty
A couple of observations:
Use <igor> and </igor> tags around the text to show Igor code in-line:
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
Function TestCompile(ctrlName) : ButtonControl
	String ctrlName
	Make/O junk
	Variable j=7 // show what happens when you run this code
	if (j==7)
		String JunkStr="HeresJunk_"
		String JunkStr2="HeresJunk2_"
		Duplicate/O junk $JunkStr
		Duplicate/O $JunkStr2  // SHOULD NOT COMPILE ?
It is true that the compiler accepts only one arg to Duplicate when two are needed.
Running the code does give a run-time error "expected wave name" on that line.
The compiler author could explain why, but I suspect it is because of the complexities of using $stringExpression.
jtaylor
OK Thanks. However, for me this issue is somewhat more concerning, since a similar line of erroneous logic was present in the heart of a code that saves my experimental data (I did not write the code, but I have been trying to understand it). Two faulty lines such as this were immediately adjacent to the line that saves my data to file. No run time error was ever reported on this machine.
Larry Hutchinson
This had nothing to do with the complexity of the compiler with $ expressions.
Duplicate wave0
would also not give an error until runtime.
Duplicate was not checking for zero destinations. Now it does. The next (tomorrow's) nightly build will have this change. You can get the nightly build here:
http://www.wavemetrics.net/Downloads/latest/
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
