Are there some program references for a beginner learning how to make procedure?
Hi everyone,
Thanks a lot.
hrodstein
If you have not done at least the first half of the Igor guided tour, choose Help->Getting Started and do the tour.
Next, here are the chapters in the Igor PDF manual that you need to read to get started with Igor programming:
IV-1: Working With Commands
IV-2: Programming Overview
IV-3: User-Defined Functions
To open the manual, choose Help->Manual.
You can find the same material in the help files by executing these commands:
DisplayHelpTopic "Working With Commands"
DisplayHelpTopic "Igor Pro Programming"
Learning programming is a three-step process:
1. Read
2. Experiment
3. Repeat from Step 1
