Index out of range for customized indices
I am trying to write a function that chooses the index of the most often occurring value in a wave. In context, I'm trying to find the most common voltage in a voltage trace in a wave's time window from 3 to 3.5 seconds. Thing is, I chose to change the indices using SetScale/I, to go from -.070 to -.010, incrementing by .00025. I've added some comments in all caps so help clarify how it works. When I run it, the debugger gives an error saying "Index out of range for wave "yVarCandidates."
Here is the code:
Function/D findMode(w)
wave w
variable ic
variable yvar
variable minVolt = -0.070//mV
variable maxVolt = -0.010//mV
variable increment = .00025//mV
variable mostCommonY = minVolt //WILL BE USED AS THE STARTING POINT FOR FINDING THE MAX, SEEN IN THIRD FOR LOOP
Make/D/O/N = ((maxVolt - minVolt) / increment) yvarCandidates
//sets the range of indices for above wave
SetScale/I y, minVolt, maxVolt, "mV", yVarCandidates//THIS IS THE PART THAT MAY BE GIVING ME PROBLEMS
//IF A GIVEN INDEX IS CROSSED BY VOLTAGE TRACE, A "TALLY" IS ADDED TO IT.
for(yvar = minVolt; yvar < maxVolt; yvar += increment)//goes from -70mv to -10 mv just to be safe
for(ic = x2pnt(w, 3); ic < x2pnt(w, 3.5); ic += 1) //3 and 3.5 is the X value and not the pnt (index, rather),
// it is not always a round integer; its in seconds
if((w[ic - 1] < yvar && w[ic] > yvar) || (w[ic - 1] > yvar && w[ic] < yvar))//if it crosses the thing
yvarCandidates[yvar] += 1
//GO THROUGH THE WAVE AND FIND THE MAX, RETURN ITS INDEX, WHICH ACTUALLY CORRESPONDS TO THE MODE VOLTAGE .
variable i
for(i = minVolt; i < maxVolt; i += increment)//goes from -70mv to -10 mv just to be safe
if(yVarCandidates[i] > yVarCandidates[mostCommonY])//if it crosses the thing
mostCommonY = i//equals idnex, which sould also be the index
endfor//DEBUGGER POINTS HERE, BUT OF COURSE IT IS REALLY ERRORING OUT INSIDE LOOP
KillWaves /Z yvarCandidates//save memory
//RETURN A DOUBLE REPRESENTING THE MOST COMMON VOLTAGE
return mostCommonY
I'm new to Igor so I'd appreciate any input you can offer about my question, and if anything else bothers you, it would be very helpful if you pointed that out too.
DJackson
When you use square brackets to index a wave, the index must be in terms of point number.
If you want to index the wave in terms of X value, you need to use parentheses, not square brackets.
For details, execute:
and read through the next subtopic, "Indexing and Subranges".
Also, anytime you have code that marches through waves point-by-point, you should look for another way to do it. I'm not sure what you are attempting but something like WaveStats or FindAPeak might allow you to eliminate the loop.
Finally, when using X indices, you need to be aware of roundoff, because floating point numbers often do not exactly represent a value. For that reason, if you do have to write a loop, it is usually better to do it in terms of point number.
November 7, 2015 at 05:53 pm - Permalink
I tried replacing the brackets with parentheses but the same error occurred. I'm going to make the way I go through this wave more efficient, less redundant thanks to your ideas. Unfortunately, there does not seem to be a function in Igor that automatically finds the mode. If you know of a way let me know. Also, wouldn't many if not all of these preprogrammed methods just march through waves too?
November 9, 2015 at 07:14 am - Permalink
November 9, 2015 at 10:47 am - Permalink
I misunderstood what you are attempting to do because your original post started with:
which is not finding the mode.
I think doing a histogram, using the Histogram operation, followed by finding the X location of the maximum value of the histogram, using WaveStats, might do it.
If by preprogrammed you mean built-in, yes, they would march through waves. But marching through waves in C code, which is what Igor does internally, is much faster than doing it in Igor code.
November 9, 2015 at 12:57 pm - Permalink
November 13, 2015 at 05:25 am - Permalink
