Changing graph axis from bottom to top
I have a graph where the Y wave is set to the left axis, and the X wave is set to the bottom axis. Is there an easy way to switch either of these axes to the other side (i.e. right and top axes) of the graph without having to totally remake the graph? I see that if I make a graph macro of the original, its possible to just manually edit the code so the axis is on the other side, but I'm hoping for more a 'switch axis' button kind of solution.
Thanks
JimProuty
In the Modify Graph dialog there's a "Swap X and Y Axes" checkbox that'll do what you want.
