Stacked category plot with z wave
I am new to using Igor and am trying to create the attached graph. Unfortunately, I am having little success. Is there a way to do this without manually programming it as an image plot? In either scenario, how would I go about recreating this graph?
JimProuty
This can be done by combining 4 category plots in one graph (using multiple bottom axes, one per category plot).
The stacked bars can be done by using either Draw to Next Grouping (what I used) or Stack on Next, depending on what data you're starting with.
The coloring/shading can be done using color as f(z).
Here's the recreation macro of an example of only one of the four category plots:
Window Graph0() : Graph
	Display /W=(96,176.75,490.5,485) wave4,wave3,wave2,wave1,wave0 vs textWave0
	ModifyGraph rgb(wave3)=(65280,0,52224),rgb(wave2)=(0,12800,52224),rgb(wave1)=(0,52224,0)
	ModifyGraph hbFill(wave3)=2,hbFill(wave2)=2,hbFill(wave1)=2,hbFill(wave0)=2
	ModifyGraph toMode=1
	ModifyGraph zColor(wave4)={wave4fz,0,8,Grays,1},zColor(wave3)={wave2fz,0,8,Grays,1}
	ModifyGraph zColor(wave2)={wave2fz,0,8,Grays,1},zColor(wave1)={wave1fz,0,8,Grays,1}
	ModifyGraph zColor(wave0)={wave0fz,0,8,Grays,1}
	SetAxis/A/E=1 left
EndMacro
The fake data I used was this:
textWave0	wave0	wave1	wave2	wave3	wave4	wave0fz	wave1fz	wave2fz	wave3fz	wave4fz
E		1	2	4	10	20	4	2	2.8	1.5	0.5
NE		1	2	4	10	20	7	6	1	2.5	1.1
NNE		1	2	4	10	20	7.5	6	3	2.8	1.7
Note the trace order: I put the waves with the biggest values in the "back" by appending them to the graph before the waves with smaller values.
