Waves get zero values after calculations
Hello and happy new year,
I have a netcdf file, which contains meteorological parameters, which need correction before any use.
After loading this file you can see parameters and their correction factors.
So eg. I do:
Function test2()<br />
<br />
wave/c nc_z<br />
wave nc_var3_scale_factor, nc_var3_add_offset<br />
<br />
duplicate/o/c nc_z, nc_z1 <br />
<br />
nc_z1=nan<br />
<br />
nc_z1=nc_z*nc_var4_scale_factor[0]+ nc_var4_add_offset[0]<br />
<br />
I have uploaded the nc file here:
http://www.megafileupload.com/qRr0/rel_vort.nc
After that the nc_vo1 wave gets only zero values.
What could be the problem?
HJDrescher
Debugging should raise a wave-reference error:
You declare
but use
and
--> "3" vs "4"
HJ
JimProuty
I don't see nc_vo1 listed in your code anywhere, so your difficulty is hard to diagnose.
And the NetCDF XOP I found couldn't load your data file; how did you get it into Igor?
You should attach your experiment instead of the data file.
HJDrescher
I tried your algorithm and got "normal" numbers.
Could you post a minimal example that reproduces your issue (make waves and do arithmetics)?
...factor[0] and ...offset[0] are non-zero? -- Really checked? ;-)
HJ
steeve88
Hello and thank you for your reply,
concerning the way that I load my this nc file. A guy from the forum gave me an extension for Igor, because this files are a bit "weird".
However, I think that finally I found the solution. The only I did was to make a new wave and put the data I wanted from the nc_vo into my new wave. It might be a kind of different type (?) of wave. I am not sure.
For a reason that I don't know, when I multiplied and summed these factors, a kind of rounding took place. So, all values were really small (order of 10^-5), so the became 0.
