Import Floating Point TIFF
a.kaiser
Mon, 10/12/2009 - 05:20 am
using the /F-flag with the ImageSave procedure I can save floating point TIFFs without normalization. However, I do not find any way to open again. ImageLoad does not know the /F-flag and normalizes my files when opening. Is there any way to re-open floating point TIFFs with Igor?
Regards,
Alex
You do not need to add /F in ImageLoad. The TIFF file contains the full description of the data stored in it so the correct waves are created when you read it in. You can try the following:
Make/n=(100,100) ddd=x*y
ImageSave/T="TIFF"/F ddd
ImageLoad/T=TIFF ddd
I hope this helps,
October 12, 2009 at 09:12 am - Permalink
I thought I tried it before, but I suppose I used /F in conjunction with /D=16 and then integer 16-bit-TIFFs have been created.
October 13, 2009 at 05:58 am - Permalink
