loading several files
Hi, i'm not so confident with IgoPro (my version 4.0.5.1 -old, I know) and i am trying since a long time to write a macro (or a function) to import several *.dat files (all in the same repertory).
I have tested several macro but none is working.
my files are *.dat and compose in 3 columns with a text header. My objectives is just to import all the dat files each in a datafolder, ideally with the file name.
Is there anything allready writen to do that? of course there is a post treatment of my data, but the macro I wrote is working (but works by file by file, and some times I have tens of files...)
thank for help or advices
Ludovic
ps: example of files
VGS Id@VDS=NaN Ig@VDS=NaN
1.00000E+0 2.55214E-3 -7.40290E-12
9.75000E-1 2.84232E-3 4.16636E-11
9.50000E-1 2.80483E-3 4.01139E-11
9.25000E-1 2.73276E-3 4.15683E-11
9.00000E-1 2.65699E-3 3.90291E-11
8.75000E-1 2.57470E-3 4.22239E-11
8.50000E-1 2.50296E-3 4.05788E-11
8.25000E-1 2.42457E-3 4.04000E-11
8.00000E-1 2.35374E-3 4.63009E-11
7.75000E-1 2.28333E-3 4.51803E-11
7.50000E-1 2.20682E-3 4.58121E-11
7.25000E-1 2.13451E-3 4.70042E-11
7.00000E-1 2.06123E-3 4.39048E-11
6.75000E-1 1.98412E-3 4.64082E-11
6.50000E-1 1.91094E-3 4.15087E-11
ChrLie
this should work, at least in Igor 6 - The LoadWave command may need some adjustment according to the structure of your *.dat files.
Function FileImport()
	NewPath/O PathName	//prompt for folder in which the files are
	if (V_flag == -1)   //User cancelled dialog
		return -1
	string ListOfFiles = IndexedFile(PathName, -1, ".dat")	// Get list of *.dat files in folder
	String CurrentFile = ""
	variable i
	do
		CurrentFile = StringFromList(i, ListOfFiles)
		if(strlen(CurrentFile)==0)	// no more file to import
			break
		NewDataFolder/O/S $CurrentFile   //make new datafolder
		LoadWave/A/D/J/W/K=0/V={" "," $",0,0}/L={0,1,0,0,0}   /P=PathName CurrentFile
		SetDataFolder ::
		i+=1
	while(1)
Cheers
Christian
Ludovic
Hi Christian,
I will find in my lab the V6 and try as soon as possible the function you sent me.
thanks a lot
Ludovic (a beginner)
