How to display 1d row of 2d data using scaled dimension ?
I have a simple question.
I want to display 1d row data graph of 2d matrix data using scaled dimension index.
But, for example,
"Display 2Dwave[](20)"
is not work.
How can I do this easily ?
Thank you in advance.
You need to execute:
Variable columnIndex = ScaleToIndex(2DWave, 20, 1)
Display 2DWave[][columnIndex]
The ScaleToIndex function was added in Igor7 so, for this to work with Igor6, you also need this:
#if IgorVersion() < 7.00
Function ScaleToIndex(w, scaledIndex, dimension)	// Based on help for x2pnt
	Wave w
	Variable scaledIndex
	Variable dimension
	Variable offset = DimOffset(w, dimension)
	Variable delta = DimDelta(w, dimension)
	Variable index = (scaledIndex - offset) / delta
	index = round(index)
	return index
#endif
