Getting the data folder of a wave in the top graph.
Function iMaxCalc() String list = TraceNameList( "", ";", 1), maxWave //gets waves in top graph Variable numItems = ItemsInList( list ), i, y_Max, y_Min, lengthh, x_Max //variables for(i=0;i<numItems;i+=1) maxWave = stringfromlist(i,list,";") //gets the first listed wave print maxWave //prints the name for reference Wave workingWaveY = $maxWave //should reference workingWaveY to the name of the wave gotten in the first part.. doesn't work... probably due to being in the wrong data folder Print GetWavesDataFolder(workingWaveY,1) //doesn't work because the above didn't work endfor end
How am I supposed to get the data folder for the wave before being able to make a wave reference using the wave's name?
In fact, the "Wave" statement doesn't work even if I manually set it to the right data folder... (It does work if I manually type in the data folder's path into the procedure, but then it's a chicken and the egg type problem, see below.)
Wave workingWaveY = $("root:LSVCompilationTrimmed:'040815_650CH3Cl_CH4_Cl':" + maxWave)
Works, but doesn't help me.
(Yes, I know a different command is recommended than GetWavesDataFolder, but I just wanted to see if it knew where it was, and this command returned the full path, wasn't sure if a data folder reference would print or not...)
The full path for the first wave in the list should be this ... root:LSVCompilationTrimmed:'040815_650CH3Cl_CH4_Cl':'1606Methane2.0_0pmaLSV2_0'
Alternately, you could use TraceNameList to get a list of trace names and then use TraceNameToWaveRef to get a wave reference to the corresponding Y wave for each trace.
May 5, 2016 at 10:38 am - Permalink
Ah, traceNametoWaveRef works well. That's the magic keyword I was looking for that did what I wanted. Works super well, thanks.
May 5, 2016 at 11:52 am - Permalink
I wasn't sure how to do degree minute second math in igor, so I just did it manually by multiplying and dividing by 60 when necessary.
May 5, 2016 at 12:34 pm - Permalink
