from PL spectrum to CIE plot
I would know if there is an IGOR PRO procedure to estimate the CIE coordinates from a photoluminescence (PL) spectrum.
Furhermore, I would plot these coordinates (x,y) in a CIE diagram using IGOR PRO.
https://en.wikipedia.org/wiki/CIE_1931_color_space
thanks
Igor
First I'd like to point out a couple of resources in this field:
1. ImageTransform contains a number of color transformations e.g., rgb2xyz, xyz2rgb, etc.
2. In WaveMetrics Procedures:Image Processing folder you will find colorSpaceConversions.ipf that contains various colorspace conversions.
Now for the task at hand. The direct approach is to obtain the spectral response curves for X Y and Z. These are called e.g., "CIE 1931 Standard Colorimetric Observer", ( http://www.cie.co.at). You then multiply that by your spectral data and integrate to obtain the XYZ values.
If an approximation is sufficiently good for your application check out http://www.ppsloan.org/publications/XYZJCGT.pdf.
I hope this helps,
