Gizmo- change camera zoom
Hi there,
Sorry to bother you with what seems like a trivial problem, but I can't seem to figure it out. I've made a gizmo plot, and I would like to export it. However, my desired angle clips the bottom corner of one of my axes labels. I could just try a different angle or fiddle with the axes sizes, but it seems like there should be an obvious way to just change the scaling/zoom of the gizmo plot.
Joel
joelkelly
Also, is there a way to control the resolution of exported PICTs from Gizmo? The resolution seems limited right now by the size of the window, which limits it for publication purposes.
ChrLie
Joel,
if I understood it correctly, open the Gizmo Info window --> Display List --> append new operation --> Scale. Enter a scaling factor. Look at the display list and drag the scale item to the top of the list.
Christian
Igor
Hello Joel,
General scaling as suggested above would work. A slightly better way of doing this would be to insert an ORTHO operation at the top of the display list. By default all 6 ortho values are +-2. You can increase these symmetrically to say +-2.05 and it should do the job for you.
bridges
It would be really nice if this was controlled with the scroll wheel on the mouse, instead of a dialog box requesting 6 numbers (which in most cases will all be the same + or -).
