How saving multi-graphs
during my work with IgorPro, I work with a lot of data and so with a lot of graphs.
Every time I have to save graphs, with "SAVEPICT as __", according to you there is a command, or create a function, that allows me to save all open graphs simultaneously without making one at a time, manually?
hrodstein
I have not tested this function.
If you are not familiar with Igor symbolic paths, execute:
DisplayHelpTopic "Symbolic Paths"
Function SaveGraphList(pathName, list)
	String pathName			// Name of Igor symbolic path
	String list				// List of graph names
	// You may need to tweak these parameters
	Variable exportType = -5		// See /E for SavePICT
	String extension = ".png"
	Variable resolution = 576	// 8 x screen resolution
	Variable numGraphs = ItemsInList(list)
	Variable i
	for(i=0; i<numGraphs; i+=1)
		String name = StringFromList(i, list)
		String fileName = name + extension
		SavePICT/O/P=$pathName/E=(exportType)/B=(resolution)/WIN=$name as fileName
hrodstein
and you could use WinList("*", ";", "WIN:1") to create a list with all graphs
Yes. I meant to include this:
Function SaveAllGraphs(pathName)
	String list = WinList("*", ";", "WIN:1")
Carlo
thanks.
I write that procedure and I create a folder in C:\A, than I load 3 graph: Graph0, Graph1, Graph2 (wave0, wave1, wave2).
But when i run
SaveAllGraphs("C:\A")
This error appear: While executing SavePICT, the following error occurred: no symbolic path of that name
Carlo
hrodstein wrote: You need to learn about Igor symbolic paths. Execute:
I just read the HelpTopic, and:
	Variable exportType = -8		// See /E for SavePICT
	String extension = ".pdf"
	Variable i
	for(i=0; i
when I write in the command line SaveAllGraphs("C:\A:"), appear the error!!!
Carlo
I just read the HelpTopic, and: when I write in the command line SaveAllGraphs("C:\A:"), appear the error!!!
	Variable i
	for(i=0; i
HJDrescher
"C:\A:" is not a symbolic path. The error message is correct.
It is neither a valid windows folder nor a macintosh path.
For how to get from folders to symbolic paths, please read the help file carefully.
HJ
Carlo
HJDrescher wrote: "C:\A:" is not a symbolic path. The error message is correct.
HJ
OK....so, I load my two wave( a general file txt), than display waves ad graph.
Than load that procedure:
saveAllgraphs("C\Users:\Carlo\Save")
Carlo
hrodstein wrote: "C\Users:\Carlo\Save" is not the name of an Igor symbolic path.
So I don't understand!
I now create a NewPath with this command
Carlo
Ok Now it work!
I don't Understand why before not worked!
If i've load 3 graphs, it juts save 3 files with the same graph, not with 3 different files
hrodstein
the procedure save only one graph 3 time
That's because of a mistake I made in the SaveGraphList function.
You need to add /WIN=$name to the SavePICT command.
I will fix the original post.
Carlo
Good! Now it work perfectly ! thanks
