Ensuring unique trace names
I'm setting up procedures that automatically plot certain waves in each of several nested data folders. I'm using the /TN command to ensure that I can modify each trace individually, despite the fact that they will all have the same wave name.
    string yN=ywaven+foldername+subfoldername
    appendtograph /W=$chartname /L=$ywaven ywave /TN=$yN vs xwave
    modifygraph /W=$chartname rgb($yN) = (red,green,blue)
If yN happens to exist already due to plotting vs a different x-wave in a previous call, or because yN exceeds string limits, I understand that Igor will use instance notation to change the trace name from whatever yN is to "yN"#1.
Is there a way for me to know that the trace name has been modified with instance notification so that the last line modifies the trace I just appended instead of the first instance named yN?
I experimented with using the uniquename function, but I don't think there is an object type that works for traces.
I used checkname(tracename,15) for both an existing and non-existent trace name on the graph in question, and both returned -1.
Thanks! I agree, that's the way to do it, if there's not a more direct route.
I had started to write a function to run a for-endfor loop to check (and modify) the proposed trace name vs all the elements in TraceNameList, but thought that there might be a more elegant way to do so via a built-in function.
It's also worth noting that if you're using a procedure to create trace names, you need to be aware of the maximum allowable length for a trace name. When I execute this code:
function maketracename()
wave ywave
display
string tn="a000000000000000000000000000001"
appendtograph ywave /TN=$tn
       tn="a000000000000000000000000000000000001"
       tn="a000000000000000000000000000000000000000000000000000000000001"
print tracenamelist("",";",1)
the output from the
 print tracenamelist
command is the following:
  a000000000000000000000000000001;a000000000000000000000000000000;a000000000000000000000000000000#1;
Applying
strlen()
to each of the entries in the
tracenamelist
output shows an output of 31, 31, and 33: this suggests that the maximum length that you can use for a trace name request is 31 bytes, but Igor can add the "#1", "#2", etc. to the end of an identical trace name to differentiate between them and will store that difference.
Understanding that difference is important to proper handling of automatically generated trace names.
I think
If (StringMatch(TraceNameList(graphNameStr, separatorStr, optionsFlag ), "*"+matchStr+"*" ))
is rather elegant if it's not invoked too often.
In your example, even quotes for liberal names, e.g. '1st trace', do not work. That's an interesting point. I assumed that the #n versions just use liberal names. But obviously it works in a different way.
HJ
You can try to use the hash function with the sha-256 algorithm (
displayhelptopic "hash"
So you would be generating the name strings:
string trace_name = name_prefix + num2str(number)
then hashing this string:
 string trace_name_hash = hash(trace_name , 1)
and hoping for no collisions (your uniqueness requirement) on the hash function. The last statement can be pretty reasonable for any meaningful set of objects to be hashed.
Good luck.
[edit] of course, you would have to keep track of which trace_name corresponds to which trace_name_hash in a separate text wave.
I would tackle the problem from a different side.
Set every trace to something unique via "T1, T2, ..." and then add some metadata using the userData keyword of
ModifyGraph
. Using the userData you can then access any trace you want without having to know about its name.
You can use FindListItem or WhichListItem functions to figure out if a given item is already in the list. Checking every time you add a new trace may make it work pretty slowly if you have hundreds of traces. Using the built-in functions to check if the name is already in the list will be faster because it uses built-in code, but can still be slow.
