Waterfall Plot y vs z axis? (Possible to scale the angled axis?)
Documentation on igor's waterfall plots says that the Z axis is on the left side and the Y axis is on the right, angled. This seems backward as a waterfall plot is a bunch of x-y data stacked along a z axis. It doubly doesn't make sense because of the option to scale the "Z axis" in the "newwaterfall" command. (Would make more sense to be able to scale the angled axis.) I realize that it's just nomenclature, but it actually pertains to a question I have.
Does the "wavez" part of the "newwaterfall" command scale the angled axis, or does it scale the vertical axis? For example, if I wanted to scale the angled axis (distance between the x-y plots)non symmetrically to correspond with certain times, could I do that? (So perhaps plot 1 and plot 2 would be "k" distance apart, while plot 2 and 3 would be "j" distance apart.)
June 27, 2016 at 10:58 am - Permalink
Thank you.
June 27, 2016 at 11:01 am - Permalink
June 7, 2018 at 08:15 am - Permalink
June 7, 2018 at 10:40 am - Permalink
