Create polar geographic projection of 2D matrix
I was hoping to find a way of plotting a 2D wave with dimensions corresponding to northern hemisphere longitude/ latitude coordinates as a polar image, i.e. centered on the North Pole, looking down.
An example of what I am aiming to do is in the attached .pxp..I want to go from the Mercator plot in graph 0 to something like the polar image displayed in graph 1 (without the text and boxes).
Thanks in advance for any help you are able to give!
(1) for simplicity, extract latitude and longitude waves from W_geometries
(2) create polar coordinate waves wX = (90 - latitude)*cos(longitude*pi/180) and wY = (90-latitude)*sin(longitude*pi/180)
(3) display wY vs wX for a polar projection of the continent boundaries
(4) in your Procedure file, , and convert into wavex, wavey, wavez:
(5) as above, transform waveX and waveY into Polar-ized wxi and weta
(6) display weta vs wxi into a polar shaped "grid" and then set as f(z) the color from wavez.
I hope this helps. I suppose IP7 can do your requirement more simply, but I am stuck for now with IP 6.37
Further thoughts: Actually the modification to Polar graph is not bad, and avoids making your own transformation, if you use the same waveY vs waveX (colored by waveZ) strategy. Just remember that the radius coordinate is 90 - latitude (for polar origin at 0).
July 14, 2016 at 04:30 am - Permalink
and http://www.igorexchange.com/node/6286#comment-10930
July 14, 2016 at 01:33 pm - Permalink
