Slider won't move continuously in IgorPro 7
When the following is run in Igor 6, the slider can be grabbed and continuously moved (updating images in panel). In Igor 7, I can click a point in the range of the slider and it will move there, but it won't perform continuous motion. It just sticks in one place after click.
Function SliderProc_3(sa) : SliderControl
	STRUCT WMSliderAction &sa
	switch( sa.eventCode )
			break
		default:
			if( sa.eventCode & 1 ) // value set
				Variable curval = sa.curval
				setactivesubwindow BGPanel
				setactivesubwindow #OImage
				ModifyImage Om ctab= {0,curval,Grays,1}
				setactivesubwindow #EImage
				ModifyImage Em ctab= {0,curval,Grays,1}
			break
	endswitch
Here is the corresponding Panel code:
        Slider SetOriginalScale,pos={6,338},size={300,50},proc=SliderProc_3
	Slider SetOriginalScale,help={"Image Scale"},labelBack=(56576,56576,56576)
	Slider SetOriginalScale,fSize=10
	Slider SetOriginalScale,limits={0,255,0},value= 98.8586956521739,vert= 0,thumbColor= (0,65280,0)
johnweeks
If you click in the slider control channel, but not in the slider thumb, it jumps to the place you clicked, but does not follow further mouse movement.
If you click in the thumb, you can drag the thumb and the control will follow the mouse movement.
This is true in both Igor 6 and 7.
ctmckee
Hi John,
In my case "If you click in the thumb, you can drag the thumb and the control will follow the mouse movement." does not perform as you note for Igor7, but does in Igor6, for the above noted code.
Clayton
johnweeks
I just noticed that your event handler makes several calls to SetActiveSubwindow. My guess is that is causing the problem in Igor 7. Instead of call SetActiveSubwindow, use the /W flag with ModifyImage, like this (perhaps):
			break
		default:
				ModifyImage/W= BGPanel#OImage Om ctab= {0,curval,Grays,1}
				ModifyImage/W= BGPanel#EImage Em ctab= {0,curval,Grays,1}
			break
	endswitch
I put a lot of effort into making window activation work correctly in Igor 7, but there are some things that simply are different.
