Restore default window position
Hello together,
I'm using Igor 6.3.7.2 on Windows 7 and have rather unsual problem: I don't know how it happend in the first place, but a dialog window moved partly offscreen, so I cannot access the top-most options or drag it back to the screen.
In particular it is the window that opens from the "Modify Trace Appearence" dialog when you click "Set as f(z)...".
When the window is opened I cannot use the command line, so I cannot control it in this way. Is there a way to restore the default window positions?
Thank you for your help!
Best regards,
Chris
s.r.chinn
I don't know whether this will work for Dialog windows, but using the mouse you might try the menu item Windows-> Control -> Set to Preferred Position.
JimProuty
If the Alt key is held down at the time the dialog is invoked, the default position is used instead of the remembered position.
