popupmenus in Igor7
The list that "pops up" from a Popupmenus in Igor7 has a vertical bar down it, with an empty space on the left side. For color table popup menu (and possibly other popup modes), this space contains a checkmark for the currently selected item. Are there any (perhaps undocumented) hooks to use this left side space with user defined menu list popup menus? Like being able to populate it with checks or bullets for selected items? I currently do something like this:
function/S NQ_ChanSelectList (chanVarStr, nChans)
	string chanVarStr
	variable nChans
	NVAR chanVar = $"root:Packages:twoP:Acquire:" + chanVarStr
	string chanSelList = ""
	variable iChan
	for (ichan =0; iChan < nChans; iChan +=1)
		if ((2^ichan) & chanVar)
		chanSelList += "\\M1" + num2char(7) + " "
			chanSelList += "   "
		chanSelList +=  num2str (iCHan) + ";"
	return chanSelList
Function testChan_PopMenuProc(pa) : PopupMenuControl
	STRUCT WMPopupAction &pa
	switch( pa.eventCode )
		case 2: // mouse up
			NVAR chanVar = root:Packages:twoP:Acquire:scanChans
			String popStr = pa.popStr
			if (char2num (popStr[0]) != 7) // adding a new channel
				chanVar+= 2^(pa.popNum -1)
				chanVar -=2^(pa.popNum -1)
			Variable popNum = pa.popNum
			break
			break
	endswitch
	//print chanVar
DisplayHelpTopic "Special Characters in Menu Item Strings"
But be aware that a PopupMenu control requires that special character interpretation be enabled, so you need to add "\\M1" to your menu items. DisplayHelpTopic "Enabling and Disabling Special Character Interpretation".
johnweeks wrote: DisplayHelpTopic "Special Characters in Menu Item Strings"
Thanks John, that works, puts the checkmark in the intended location. It looks so much better.
Note that with this method of marking selections you can't use something like
to see if an item is selected; the checkmarks are not part of the string. It is easy to redo the functions so they work properly, though.
This code uses a variable for a bitwise channel selection (0 =1, 1-2, 2=4, 3=8, etc) and a string containing the list of channels. The popmenu shows the list of channels with selected channels checked. Selecting a currently unselected channel from the popmenu selects it, selecting a selected channel deselects it.
	PopupMenu popup0,pos={1.00,1.00},size={135.00,23.00},proc=ChanPopMenuProc,title="Selected Channels"
	PopupMenu popup0,mode=0,value= #"ChanSelectList ()"
	string/G root:chanStr =  "ch0-test1;ch1-test2;ch2-test3;ch3-test4;"
	variable/G root:chanVar = 0
function/S ChanSelectList ()
	SVAR chanStr = root:chanStr
	NVAR chanVar = root:chanVar
	variable iChan, nchans = ItemsInList(chanStr, ";")
			chanSelList += "\\M1" + StringFromList(iChan, chanStr, ";")  + "!*;"
			chanSelList += StringFromList(iChan, chanStr, ";")  + ";"
	return chanSelList
Function ChanPopMenuProc(pa) : PopupMenuControl
		case 2: // mouse up
			variable chanPos = 2^(pa.popnum-1)
			if (chanPos & chanVar) // deselecting a new channel
				chanVar-= chanPos
			else // selecting a channel
				chanVar += chanPos
			break
			break
	endswitch
