"Heat map" advice/opinion
Hello all,
I have a set of 2D coords and I'd like to plot the density of these points as a "heat map" (colour-coded map of probability at every location within a boundary). In the past, I have done one of two things:
1. 2D histogram - sample number of points in a grid and use that for representation, but this can look blocky. I have around 200 points so reducing bins can look weird with smaller bin sizes.
2. ImageInterpolate (voronoi) - for each point, calculate the number of neighbouring points within some arbitrary distance and use these values as z to make a surface with
ImageInterpolate
with voronoi option.
I'm wondering if a better approach would be to make a 2D gauss at each location and sum these together (perhaps with smoothing) to make the representation.
I'm not sure how to go about doing this other approach. I've tried to investigate the new
StatsKDE
option in IP7 without much success - does it work on 2D waves?
If anyone has:
- an opinion of what is the best way to make a heat map in these circumstances
- advice on how to do the third option.
I'd love to hear it. Otherwise, feel free to tell me to take this to stackexchange instead!
Igor
In IP7 you also have JointHistogram but that would not really get you over the fact that the small number of points would give rise to "blocky" output. If you take the result of JointHistogram you should be able to interpolate it directly (not using Voronoi because your result is already on a rectangular grid).
You might also want to check out the ImageFromXYZ operation.
FWIW: I think there is value in displaying the raw joint histogram results. The interpolation could lead you to misinterpret the results.
sjr51
Thank you. I think you are right about interpolation being misleading. With so few points I can leave them as they are and set alpha at 0.5 or something so that overlapping points (as markers) appear darker.
jamie
sjr51 wrote: Hello all,
ImageInterpolate
StatsKDE
If anyone has:
This is my code from years ago to do the third option you suggest. See here, for published example involving 2D maps of labeled neurons in brain sections
  • https://www.ncbi.nlm.nih.gov/pubmed/10376741
  • It assumes that x and y wave names are the same, except for ending with "x" and "y" respectively, and are generated from dataSetNameStr
    Xmin, Xmax, Ymin, Ymax are boundaries of the output image
    Pixelsize for output image is in whatever units your data are in, and Gaussian radius is the radius of the Gaussian kernel in pixels
    // Makes a 2D histogram with Gaussian smoothing
    Function TwoDHist_Gaussian (datasetnamestr, OutputFolderPath, Xmin, Xmax, Ymin, Ymax, pixelsize, GausRadius, DisplayNow)
    	String datasetnamestr, OutputFolderPath
    	variable Xmin, Xmax, Ymin, Ymax,  pixelsize, GausRadius, DisplayNow
    	// make duplicates of the X and Y waves and trim them to Xmin, Xmax, Ymin, Ymax, plus a border equivalent to 3X the GausRadius
    	// because cells that far away could affect pixels in the desired image space. Aterwards, we will crop the image.
    	wave Xwave = $datasetnamestr + "x"
    	wave Ywave = $datasetnamestr + "y"
    	if (!(datafolderexists ("root:packages:twoDHist")))
    		if (!(DataFolderExists ("root:packages")))
    			newDataFolder root:packages
    		newdatafolder root:packages:twoDHist
    	duplicate/o Xwave root:packages:twoDHist:XWave
    	duplicate/o Ywave root:packages:twoDHist:YWave
    	Wave Xwave = root:packages:twoDHist:XWave
    	Wave Ywave = root:packages:twoDHist:YWave
    	sort  Xwave Xwave, Ywave
    	// have to get rid of NaNs, they will be at the end after a sort
    	variable ii
    	For (ii = numpnts (Xwave) -1; numtype (Xwave [ii]) > 0; ii -= 1)
    		Deletepoints ii, 1, Xwave, Ywave
    	EndFor
    	variable bs = BinarySearch(Xwave, xmin - (GausRadius * pixelsize * 3 ))
    	if (bs > -1)
    		DeletePoints 0, bs, Xwave, Ywave
    	bs = BinarySearch(Xwave, Xmax + (GausRadius  * pixelsize * 3 ))
    	if (bs > -1)
    		DeletePoints bs, numpnts (Xwave), Xwave, Ywave
    	sort Ywave Ywave, Xwave
    	bs= BinarySearch(Ywave, ymin - (GausRadius  * pixelsize * 3))
    	if (bs > -1)
    	bs= BinarySearch(Ywave, Ymax + (GausRadius * pixelsize  * 3))
    	if (bs > -1)
    		DeletePoints bs, numpnts (Ywave), Xwave, Ywave
    	// Make a Gausian Blob of the required size.  After 3X the radius, the Gaussian function has fallen to about 3%, so we'll cut it off there
    	// and make the blob size 6 times the radius, plus 1 for the center pixel. We'll also blank out the corners of the square image.
    	variable GausPixWid = GausRadius * 6 + 1
    	make/o/n = ((GausPixWid), (GausPixWid)) root:packages:twoDHist:GausBlob
    	WAVE GausBlob = root:packages:twoDHist:GausBlob
    	GausBlob = ((p - 3 * GausRadius)^2 + (q - 3 * GausRadius) ^2) <  (3 * GausRadius)^2 ? e^-(((p - 3 * GausRadius)^2 + (q - 3 * GausRadius)^2)/(2 * GausRadius^2)): 0
    	// Make an  image bigger than we need, because of the margin of interaction issue
    	variable xpixels = ceil((Xmax-Xmin)/pixelSize) + GausPixWid -1
    	variable ypixels = ceil((Ymax-Ymin)/pixelSize) + GausPixWid -1
    	make/o/n=((xpixels), (ypixels)), $OutputFolderPath
    	Wave celim = $OutputFolderPath
    	celim = 0
    	//Now fill the image with the data
    	// first transform the X,Y coordinates from mm into pixel space
    	Xwave -= (Xmin  - (GausRadius  * pixelsize * 3)+ pixelsize/2)
    	Ywave -= (Ymin  - (GausRadius  * pixelsize * 3) + pixelsize/2)
    	Xwave /=PixelSize
    	Ywave/=PixelSize
    	variable numdata = numpnts (Xwave)
    	For (ii = 0; ii < numdata; ii += 1)
    		celim [max (0, (Xwave [ii] - (3 * GausRadius))), min (Xpixels-1, (Xwave [ii] +(3 *  GausRadius)))] [max (0, (Ywave [ii] - (3 * GausRadius))), min (Ypixels-1, (Ywave [ii] + (3 *GausRadius)))] +=  GausBlob [p - Xwave [ii] + (3 *GausRadius)] [q -Ywave [ii] + (3 *GausRadius)]
    	killwaves/z Xwave, Ywave, GausBlob		//  kill the temporary waves
    	//delete the extra margins of the image
    	DeletePoints /M=0  (xpixels - (3 *GausRadius)), (3 *GausRadius), celim
    	DeletePoints /M=0  0, (3 * GausRadius), celim
    	DeletePoints /M=1  (ypixels - (3 * GausRadius)), (3 *GausRadius), celim
    	DeletePoints /M=1  0, (3 *GausRadius), celim
    	SetScale/P x Xmin + PixelSize/2, PixelSize,"mm", celim
    	SetScale/P y Ymin + PixelSize/2, PixelSize,"mm", celim
    	// Display the image if so requested
    	if (DisplayNow)
    		display;appendimage celim
    		ModifyGraph width={Plan,1,bottom,left}
    		ModifyImage $nameofwave (celim) ctab= {*,*,Rainbow,1}
    I have attached a picture of some random data ovulated on its 2D gaussian blobbed equivalent
    •make/n = 250 testx, testy
    •testx = enoise (5); testy = enoise (5) + 10
    •TwoDHist_Gaussian ("test", "root:OutPut", -6, 6, 3, 16, .05, 9, 1)
    •append testy vs testx
    •ModifyGraph mode=3,rgb=(0,0,0)
    Jamie Boyd, Ph.D.
    jamie
    One additional thing you might want to do, depending on your needs, is to set the sum of the GaussianBlob to 1 after making it
    GausBlob = ((p - 3 * GausRadius)^2 + (q - 3 * GausRadius) ^2) <  (3 * GausRadius)^2 ? e^-(((p - 3 * GausRadius)^2 + (q - 3 * GausRadius)^2)/(2 * GausRadius^2)): 0 // after this line
    variable blobsum = sum(GausBlob)  //add this line
    GausBlob /= blobsum  // and this line
    so that the sum of the image will be equal to the number of points contributing to the image, for whatever size of kernel you use.
    Jamie Boyd, Ph.D.
