Making columwise operations faster?
Suppose I have two 2-dimensional waves.
make/o/n=(1000,16) w1= gnoise(1) ,w2 = gnoise(1)
Each column of each wave refer to data from a single experiment, and the column index is a different iteration of the same experiment.
i.e. w1[][k] and w2[][k] refer to two outputs of a single experiment, where k indexes the iteration of the experiment.
I want to construct a wave as follows
duplicate/o w1 w3
w3[][]=w1[p][q]*w2[999-p][q]
Is there a way to make the construction of w3 faster?
Each column is independent, so can we use multiple cores or processes (or anything else) to speed up the construction of w3?
aclight
Here's an example:
Function test()
	duplicate/o w1 w3
	Variable start = StopMSTimer(-2)
	print (StopMSTimer(-2)-start)
Function test_MT()
	duplicate/o w1 w3
	MultiThread w3[][]=w1[p][q]*w2[999-p][q]
When executed on the command line using the same Windows machine with a quad core processor:
•test() 3180.63 •test_MT() 763.69
sjr51
You could duplicate w2, reverse it and then use MatrixOp to multiply.
Function test_RV()
	duplicate/o w2 w4
	Reverse w4
	MatrixOp/o w3 = w1 * w4
On my machine
•test()
  1452.05
•test_MT()
  839.983
•test_RV()
  172.87
ChrLie
In Igor 7 you can use
MatrixOP reverseCols
, i.e.
Function test_RV2()
	MatrixOp/o w3 = w1 * reverseCols(w2)
•test()
1082.05
•test_MT()
492.495
•test_RV()
169.394
•test_RV2()
79.089
