How to duplicate a wave or matrix by a provided name using function??? [SOLVED...]
doha420du
Tue, 01/03/2017 - 12:07 pm
I am new in Igor. I am trying to plot an image after doing an operation of the given matrix.
I have written an function and it works perfectly...where I have a fixed name of the new matrix.
Function PlotRelAnisotropyImage()
wave matrix
Display;DelayUpdate
AppendImage matrix;DelayUpdate
ModifyImage matrix ctab= {-6.13085,0.465855,VioletOrangeYellow,1};DelayUpdate
Label left "Polarizer Angle (Degrees)";DelayUpdate
Label bottom "Wavelength (nm)";DelayUpdate
Duplicate matrix, RelAnisotropy
Variable numRows = DimSize(matrix,0)
Variable numColumns = DimSize(matrix,1)
Redimension/N=(numRows,numColumns) RelAnisotropy
Variable i,j,k
for(i=0; i<numRows; i+=1)
for (j=0; j<numColumns; j+=1)
k = (j*5)+90
if (k>360)
k = k-360
k = k
RelAnisotropy[i][j] = matrix[i](j*5) - matrix[i](k)
Display;DelayUpdate
AppendImage RelAnisotropy;DelayUpdate
ModifyImage RelAnisotropy ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
wave matrix
Display;DelayUpdate
Variable i,j,k
k = (j*5)+90
if (k>360)
k = k-360
k = k
Display;DelayUpdate
Now, at time of calling the function, I want to provide the name of the new matrix. How can I do that...???
I have tried in the following way... but getting many errors...
Function PlotRelAnisotropyImage(MatrixName, NewMatrixName)
Wave MatrixName
String NewMatrixName
Display;DelayUpdate
AppendImage MatrixName;DelayUpdate
ModifyImage MatrixName ctab= {-6.13085,0.465855,VioletOrangeYellow,1};DelayUpdate
Duplicate MatrixName, $NewMatrixName
Variable numRows = DimSize(MatrixName,0)
Variable numColumns = DimSize(MatrixName,1)
Redimension/N=(numRows,numColumns) $NewMatrixName
Variable i,j,k
k = (j*5)+90
if (k>360)
k = k-360
k = k
$NewMatrixName[i][j] = MatrixName[i](j*5) - MatrixName[i](k)
Display;DelayUpdate
AppendImage $NewMatrixName;DelayUpdate
ModifyImage $NewMatrixName ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
Wave MatrixName
Display;DelayUpdate
Variable i,j,k
k = (j*5)+90
if (k>360)
k = k-360
k = k
Display;DelayUpdate
Thanks in advance.
add this:
Then use newMatrix instead of $NewMatrixName thereafter.
For details, execute:
It would also be a good idea to read the entire Programming help file or the equivalent first three chapters in the PDF manual
January 3, 2017 at 01:23 pm - Permalink
I have tried as you said but it is showing me following error.
January 4, 2017 at 08:24 am - Permalink
January 5, 2017 at 07:13 am - Permalink
This is because ModifyImage takes an image name, not a wave reference. The reason for this subtle distinction is that you can append the same wave as an image to a given graph multiple times and each image must have a distinct name. This is analogous to the distinction between a trace name and a wave name. You can read about this by executing:
So the bottom line is that you need to pass an image name to ModifyImage, not a wave reference, like this:
AppendImage NewMatrix;DelayUpdate
String ImageName = NewMatrixName
ModifyImage $ImageName ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
I created a separate ImageName local variable to make this subtle distinction more evident. You could also do this, which is equivalent:
One more thing - I removed all of the DelayUpdate calls. They do nothing in a user-defined function during which updates are off by default.
Here is the function with all of the changes:
Wave MatrixName
Display
Wave NewMatrix = $NewMatrixName // Create wave reference for new wave
Redimension/N=(numRows,numColumns) NewMatrix
Variable i,j,k
k = (j*5)+90
if (k>360)
k = k-360
k = k
NewMatrix[i][j] = MatrixName[i](j*5) - MatrixName[i](k)
Display
January 5, 2017 at 07:34 am - Permalink
Till now I am having the same problem... :(
I have attached the matrix by which I am trying...
January 5, 2017 at 02:05 pm - Permalink
Also
I fixed this the same as I previously fixed the probem with the second ModifyImage command.
For clarity, I changed your "MatrixName" parameter to MatrixRef, to make it clear that it is a reference to a wave, not the name of a wave.
For the same reason, I changed NewMatrix to NewMatrixRef.
I also changed the NewMatrixName parameter to NewMatrixNameStr because it is not the name of a matrix but rather a string variable containing the name to use for the new matrix wave.
Here is the resulting function. I have marked the major changes with *** so you can see where they are.
Wave MatrixRef
String NewMatrixNameStr
Display
AppendImage MatrixRef
String ImageNameStr = NameOfWave(MatrixRef) // ***
ModifyImage $ImageNameStr ctab= {-6.13085,0.465855,VioletOrangeYellow,1} // ***
Duplicate/O MatrixRef, $NewMatrixNameStr // *** Added /O
Wave NewMatrixRef = $NewMatrixNameStr // Create wave reference for new wave
Variable numRows = DimSize(MatrixRef,0)
Variable numColumns = DimSize(MatrixRef,1)
Redimension/N=(numRows,numColumns) NewMatrixRef
Variable i,j,k
k = (j*5)+90
if (k>360)
k = k-360
k = k
NewMatrixRef[i][j] = MatrixRef[i](j*5) - MatrixRef[i](k)
Display
AppendImage NewMatrixRef
String NewImageNameStr = NameOfWave(NewMatrixRef)
ModifyImage $NewImageNameStr ctab= {-4.82601,0.74151,VioletOrangeYellow,1}
Finally, the Redimension call is unnecessary because, after Duplicate, the new matrix will have the same dimensions as the original matrix.
January 5, 2017 at 03:37 pm - Permalink
When I run the function, as an example:
It is showing me the same error like:
To speak the truth I don't understand why it is taking 'string function name'...???
January 7, 2017 at 10:14 am - Permalink
The second parameter is a string and you passed a name (and the name was apparently not the name of a string variable).
January 7, 2017 at 11:37 am - Permalink
Thanks...
January 9, 2017 at 09:14 am - Permalink
